I'm getting ready to install headers on my '98 convertible with 41K miles. Can I re-use the head and mid-pipe flange gaskets or should I plan on getting new ones? Same question on the small egr valve gaskets on either side of the header.
what system did you buy?... most come as a complete header back system all the way to your axle back and should include all the necessary gaskets and clamps to complete the assembly... I would however suggest buying new gm steel manifold gaskets regardless if your headers come with new gaskets or not unless they are also gm gaskets
