c5 windows
Old Apr 23, 2015 | 01:06 PM
lowride's Avatar
lowride
4th Gear
Default c5 windows
How can you fix loose windows on a c5 convertible
Old Apr 23, 2015 | 01:31 PM
lmrace's Avatar
lmrace
4th Gear
Pull your door pad and tighten the window track bolts. Mine would loosen up about every 2 years since I bought it new in 2001. The last time it happened I took the nuts off installed a flat washer against the door, then a star washer, then the nut. The nuts haven't came loose and my windows haven't rattled for the last 3 years. The reason for the flat washer is so the star washer doesn't eat into the door shell. Hope this helps
Old Apr 23, 2015 | 01:39 PM
lowride's Avatar
lowride
4th Gear
Cool thanks I have to replace the door panels anyway so that should give me full access to these bolts then
Old Mar 16, 2016 | 12:37 PM
Janfun's Avatar
Janfun
Thank you for sharing this. I have the same issue. Just a question before starting the job: what size star washer you use and what is the bolt size (e.g. M8).
Thanks and have a great day
JanFun
To c5 windows
