F L P Dyno Numbers ?????
Old Aug 13, 2002 | 10:12 PM
bbjohn97's Avatar
bbjohn97
Default F L P Dyno Numbers ?????
Looking for full bolt on FLP dyno #"s, anyone? Tough choice to make on FLP or SLP
Old Aug 13, 2002 | 11:01 PM
AlphaKnight34's Avatar
AlphaKnight34
Default Re: F L P Dyno Numbers ????? (bbjohn97)
I don't have a scanner, so I can't post the actuals but I had a baseline run with only a Vortex Ram Air.
Max hp=359.8@5450rpm
Max tq=409.6@4300rpm
After FLP headers, X-pipe, no cats
Max hp=394.0@5250rpm
Max tq=416.3@4750rpm
About 34 horses and 6 lbs tq :cheers:
Old Aug 13, 2002 | 11:09 PM
bbjohn97's Avatar
bbjohn97
Default Re: F L P Dyno Numbers ????? (AlphaKnight34)
34 hr, 6 tq sounds pretty good, alpha how is the noise level in the car with out the cats, noticable power increase?
Old Aug 14, 2002 | 01:13 AM
AlphaKnight34
Noise- I prefer the sound the car makes without the cats. I also have the A and A exhaust mod, and in combo with the test pipes I really enjoyed the sound of the exhaust. Not to loud, but very mean. I just put the Hi-flow cats on Fri. Significant sound difference. Almost sounds stock :sad: I don't like it at all. But I'm not into spending alot for a cat-back system without proof of solid gains
Power- Can't really tell too much difference with and without cats. Track times are about the same. There are probably some extra horses in there, but I don't think it's much. I figured I might as well put the cats on so I can be a nice, law-abiding citizen :blueangel: .......until I get a chance to get on iopen road :reddevil !!!
Old Aug 14, 2002 | 12:09 PM
Mike TexaSS's Avatar
Mike TexaSS
I dynoed at 308 RWHP with blackwing and B&B PRT's and 335 RWHP with the FLP's!!
Old Aug 14, 2002 | 08:01 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: F L P Dyno Numbers ????? (Impala SS Z06)
i gained 19 rwhp and 11 rwtq OVER B&B shorties (w/ cats) when I installed my FLPs with no cats :yesnod:
that is on a MTI H/C car
hope that helps
Old Aug 14, 2002 | 08:30 PM
Horsepower's Avatar
Horsepower
Default Re: F L P Dyno Numbers ????? (Ram Air Tony)
sig
Old Aug 14, 2002 | 08:39 PM
NJVetteGuy's Avatar
NJVetteGuy
Does anyone have the #s throughout the RPM range? I am more worried about losing torque down low in the RPM range with my gears. For me it's not worth the trade off if I lose power in the lower range to gain it up top.
To F L P Dyno Numbers ?????
