Setting valve lash and getting TDC?
Old Aug 14, 2002 | 02:43 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Setting valve lash and getting TDC?
When setting your valve lash, how do you know when pistons 3, 5 and 7 are at top dead center? Thanks
David
Old Aug 14, 2002 | 04:00 PM
davidfarmer's Avatar
davidfarmer
Default Re: Setting valve lash and getting TDC? (ScreaminDemon)
Forget that. For each cylinder, you adjust the intake valve when the exhaust rocker JUST STARTS TO MOVE, and adjust the exhaust when the intake JUST FINISHES CLOSING. Have you converted your car to an adjustable setup.
Dave
Old Aug 14, 2002 | 04:19 PM
RHILL's Avatar
RHILL
Default Re: Setting valve lash and getting TDC? (davidfarmer)
This is how to do it .... Nice and easy and not rocket science :cheers:
Old Aug 15, 2002 | 01:20 AM
ScreaminDemon
I've installed T&D shaft rockers with a solid roller setup. I'm in the middle of removing one of the heads chasing an oil leak. Can you give alittle more details. How do you go about turning the motor and how do know exactly when a valve is starting up/down? I thought each piston had to be at TDC to adjust your valvelash. Thanks
David
To Setting valve lash and getting TDC?
