Can the temperature gauge be correct?
Old Aug 14, 2002 | 08:52 AM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Can the temperature gauge be correct?
It's been really hot here in the northeast, averaging about 95 for the 3-4 days. My car outside temperature gauge displays anywhere from 103 to 106! Can this be correct? I suspect that it might be the road temperature or affected by the engine temperature.
Thanks!
Old Aug 14, 2002 | 09:48 AM
Len16's Avatar
Len16
Default Re: Can the temperature gauge be correct? (mshipon)
The highest I've read in the last few days is 101.
I find that my temperature reading is very acurate compared to the weather reports.
Old Aug 14, 2002 | 10:11 AM
pburant's Avatar
pburant
Default Re: Can the temperature gauge be correct? (Len16)
The engine doesn't influence the outside temp reading, but the hot pavement certainly does.
Old Aug 14, 2002 | 10:12 AM
TXSTICK's Avatar
TXSTICK
In the summer I have seen 131 on mine when it has been sitting in the parking lot all day. Right now it reads about 3-4 degrees over the outside temp (per the radio). Its got to be the black top putting out the heat. :reddevil :yesnod:
Old Aug 14, 2002 | 10:30 AM
Scruffy's Avatar
Scruffy
I've seen 100-101F when the air temp is 97F. Hot road surface or sitting in traffic with no air movement will influence the readout. Don't need that thing to tell me it's hot in the vert :D
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Can the temperature gauge be correct? (TXSTICK)
Right now it reads about 3-4 degrees over the outside temp....Its got to be the black top putting out the heat. :reddevil :yesnod:
:yesnod:
Old Aug 14, 2002 | 10:57 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Traveling on the highways it is usually always higher than the temp away from the road :yesnod:
Nick
Old Aug 14, 2002 | 08:11 PM
Xssesive's Avatar
Xssesive
Default Re: Can the temperature gauge be correct? (Scruffy)
:yesnod:
To Can the temperature gauge be correct?
