98c5/a4 overheating
Old May 30, 2015 | 03:16 PM
  #41
WHITLTNG's Avatar
WHITLTNG
Originally Posted by 8VETTE7
Need a little more info. When the drivers side fan comes on around 180, does the passenger side fan also come on? Do they both go off at the same time or just the drivers side???
Side question. How long have you had the car and have you driven it before in warmer (hot?) weather?
yes the passenger side fan comes on and stays on.. the drivers side does not..
had the car since 2004,, yes have had it in Miami and at the track every weekend..
Old May 30, 2015 | 03:27 PM
  #42
WHITLTNG's Avatar
WHITLTNG
Here is my buddies 99 fuse box--looks like the 2 relays are turned around.. but like u said could mean nothing! should I try turning them?
Old May 30, 2015 | 03:47 PM
  #43
WHITLTNG's Avatar
WHITLTNG
I will not make that recommendation.
I would be concerned asking someone else to "try" an electrical related change unless I had hands on myself. Basically I don't want to assume responsibility without being able to do some testing to see if the wiring to the base of the fuse box warrants changing the orientation of the relays.
Electrical experimentation can become costly in a big hurry.
But if we could get someone with a 98 to give us a picture of their fuse box and the relays were in the same orientation as on the 99, I would reconsider. Unlikely that within a model year that the fuse box wiring would have been changed. Not impossible but unlikely.
I agree!! I can post it up for anyone with a 98. BTW I really appreciate u taking time out of your weekend to help out..
Old May 30, 2015 | 03:58 PM
  #44
WHITLTNG's Avatar
WHITLTNG
Outside temp going to 101 this afternoon and the pool isn't warm enough yet (only 76) to be in it so I'm inside in the AC. Got to do something to amuse myself.
Now thats hot!! well i appreciate it! I will go ahead and post up a new thread to see who has a 98
Old May 30, 2015 | 04:02 PM
  #45
73Corvette's Avatar
73Corvette
Corvette Recycling sells the same box for 98-99
1998-1999 C5 Corvette Main Wiring Junction & Fuse Block with Fuses 15329393 OEM (12176938,12176979)
Old May 30, 2015 | 04:06 PM
  #46
WHITLTNG's Avatar
WHITLTNG
Thx.. I hope I dont have to do this, but who knows.. after sitting for nearly 3 years could be anything. atleast now we know the motor does work, even if its for a min..
Old May 30, 2015 | 04:10 PM
  #47
73Corvette's Avatar
73Corvette
I just posted that because there was some concern if there was a difference... according to the fuse box they sell to the public it's the same... you have a picture of a buddies for comparison on orientation of the relays... according to this fuse boxes are the same...and by your buddies fuse box... the relays in question are in the WRONG orientation.
Plus for whatever it's worth .... every pic I've seen has the little dog ear on the relay facing the fender like the ONE you have that you haven't changed and NOT like the other two you replaced... just sayin...
To me the evidence is mounting that those two are in the WRONG orientation..
Old May 30, 2015 | 10:28 PM
  #48
WHITLTNG's Avatar
WHITLTNG
Chuck,
I just sent you an email with 98 fuse box pic!
Old May 30, 2015 | 10:49 PM
  #49
WHITLTNG's Avatar
WHITLTNG
Responded to your email.
Based on the picture you just emailed and the picture from your friends 99 above, it looks to me like your relays are installed wrong. I am comfortable suggesting that you turn the two relays in question, 43 and 45, 180 degrees so that the cut corners face the fuse box. Post back how the fans operate when you have given them a try.
Will do!! I will let you know
Old May 30, 2015 | 11:04 PM
  #50
WHITLTNG's Avatar
WHITLTNG
Just to make sure,,,, BOTH fans should be on by 226?
Old May 31, 2015 | 07:33 AM
  #51
73Corvette's Avatar
73Corvette
Old May 31, 2015 | 11:05 AM
  #52
WHITLTNG's Avatar
WHITLTNG
Well i just test drove it and once again NO DRIVERS SIDE fan.. let it get up to 250 and only the passenger side stays on.
Old May 31, 2015 | 11:06 AM
  #53
WHITLTNG's Avatar
WHITLTNG
The drivers side did come on at 180, but only stays on for not even a min.
Old May 31, 2015 | 11:14 AM
  #54
WHITLTNG's Avatar
WHITLTNG
I also switched the relays to make sure they both work, and they did..
Old May 31, 2015 | 01:19 PM
  #55
WHITLTNG's Avatar
WHITLTNG
I need some time to review all the posts in this thread before going any further. I am thinking you will need to check electrical connections as well as grounds based on the continuing symptoms especially one fan going off after running a short period of time.. I will post back later today......
Thx, Chuck!
Old Jun 1, 2015 | 08:57 AM
  #56
WHITLTNG's Avatar
WHITLTNG
http://forums.corvetteforum.com/c5-t...erheating.html
I'm not totally convinced that the cooling system does not have air trapped in it. Please look through the above thread and if you have time please use the procedure described to insure that all air is bled out of the system. Let me know if you have questions about using this procedure.
Ok, I will also check this afternoon.
thx
Old Jun 2, 2015 | 05:59 PM
  #57
WHITLTNG's Avatar
WHITLTNG
Chuck can I pull off the black tube or do i have to unbolt the two bolts on the heads?
also i checked the sensor that is behind the altenator and it is fine..
To 98c5/a4 overheating
Old Jun 2, 2015 | 06:32 PM
  #58
WHITLTNG's Avatar
WHITLTNG
If it were me I would loosed the bolt and wiggle the metal tube to get the coolant to start flowing. I would also do it with the engine running so the water pump is trying to move coolant. The reason I wouldn't just remove the black hose is because of the small diameter of the steel tube, the age of your car and this thing called rust/scale that forms on steel. Do both sides!!!!!!!
https://www.corvetteforum.com/forums...stumped-2.html
post #27.......
Of course you can try just the rubber tube and see if air followed by coolant flows out.
Either way let if flow as you can easily add several ounces of distilled water or 50/50 mix of coolant and distilled water to the surge tank when you are done to bring the coolant to the proper level..
This is NOT going to solve the issue with the fan operation but I think the car is running way to hot and I think it is because of trapped air.
Ok..I will remove fill tank cap, then I will just crack the drivers side bolt. thx!!
Old Jun 2, 2015 | 06:41 PM
  #59
WHITLTNG's Avatar
WHITLTNG
Start on the drivers side and after you finish that side do the same to the passenger side.
Will do!
Old Jun 2, 2015 | 07:57 PM
  #60
WHITLTNG's Avatar
WHITLTNG
Well i loosned the drivers bolt and it took about a min. then coolant came streaming out.. same thing for the passenger side.. (did not hear any air releasing) but u figure there had to be some in there for it to take a min. to flow coolant. So i test drove it and it seemed it took longer to over heat, but it still did..260 then I shut it down. Man I dont see what else to possibly try! There has got to be something going on with that fan not coming on.. say a rodent(rat) did chew through something,, how would i ever be able to tell? Should I take it to the dealer and have them check it at this point?
