question about volant dual air intake system
Old Aug 14, 2002 | 01:20 PM
Brad-Vette's Avatar
Brad-Vette
Default question about volant dual air intake system
I installed the system but the hose that is attached to the accordian style air duct now has no place to go. how do I attach it to the black air duct that came with the kit?
Thanks,
Brad
Old Aug 14, 2002 | 04:59 PM
Scruffy's Avatar
Scruffy
Default Re: question about volant dual air intake system (c5vette)
:confused: I had a Volant installed about a year ago. I had no hose to the accordian coupler?? Are you referring to the air temp sensor on the air bridge?
Old Aug 14, 2002 | 06:02 PM
alanh's Avatar
alanh
If you are talking about the fuel pressure regulator hose, you have to make your own hole to plug it in. Only 97 & 98 had these adjustable pressure regulators with the hose. Or you can leave it off & plug the regulator. Installing a low restriction air intake defeats the operation the vacuum regulator was designed to do, so it won't be doing much any way.
[Modified by alanh, 4:06 PM 8/14/2002]
Old Aug 15, 2002 | 12:00 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Brad, call us if you need help!!!
Nate
To question about volant dual air intake system
