From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Originally Posted by SDLS1Rider
My condenser pipe was rubbing up against a sheet metal shroud and made a fine cut in the pipe. I need to replace the condenser.
While researching on how to replace the condenser, some references said that the accumulator and expansion valve need to be replaced also.
Is this true?
The dryer most definitely was on it's last legs anyway, and will have drawn all moisture it can from the air now that the system is open, so yes, that needs to go. The valve is so cheap, why not. It's like $2.
I'm an advocate of Ice32 additive. I'd put that in as well.
