Prothane Bushings Sleeves?
Old May 9, 2015 | 10:26 AM
HT99's Avatar
HT99
Default Prothane Bushings Sleeves?
Received kit for a 99 C5 (7-2014, front and rear), however the aluminum sleeves were not included. Removed the original rubber bushings and tried to remove the sleeve without success.
Tried to cut/torch the rubber; messy, smelly and to much effort.
It appears the rubber is fused on to the aluminum sleeve.
Dealer only sells sleeve already in rubber bushing.
Anyone know where I can buy a set of sleeves?
Or do I have to return the Prothane and buy VB&P or Pfadt complete bushing and sleeve kit?
Other ideas?
Old May 9, 2015 | 01:35 PM
dadaroo's Avatar
dadaroo
I would say you bought them from the wrong vendor.
Old May 9, 2015 | 04:56 PM
HT99's Avatar
HT99
I can't believe any company would sell C5 bushings without sleeves.
Unless someone can clue me into where I can can a set of sleeves, I'm returning the Prothane and picking up a real set from VB&P.
Old May 10, 2015 | 06:29 PM
Deputy_Dangle's Avatar
Deputy_Dangle
I installed the Prothane kit on my car. I burnt the sleeves out with a torch, the cleaned them up with a soft wire wheel. Worked Great and only took about an hour.
You can also sit the bushing in acetone overnight and it will soften the rubber.
Old May 11, 2015 | 10:02 AM
lionelhutz's Avatar
lionelhutz
Try a drill and appropriately sized bit and just keep drilling at the rubber until you chew most of it out.
Old May 12, 2015 | 07:25 AM
HT99's Avatar
HT99
Took the easy way out, returned the Prothane and bought a set with sleeves from VB&P for $370 shipped (includes lower rear shock tower bushings).
When I have free time I'll try your suggestions and perhaps sell the cleaned sleeves. I'm sure someone will want them.
To Prothane Bushings Sleeves?
