What is this????
Old Aug 14, 2002 | 11:24 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default What is this????
when I was lowering my car I noticed a plug hanging down on the front passenger side of my car. It is in front of the air damn. I looked evrywhere and could not find out where it goes. I even checked both of my fathers Corvettes and didn't see a plug close to that location. :confused:
Old Aug 14, 2002 | 11:43 PM
scool93535's Avatar
scool93535
Default Re: What is this???? (2C5only21)
By plug I assume you mean an electrical connector. There are 2 in that region. 1 connects the front end lights, fog, turn signal, etc, but not head lights and the other should go up inside the air cleaner area for the under hood light. The under hood light only has 2 wires on it. Both should be tied down near their ends? Broken tie down maybe?
Old Aug 14, 2002 | 11:45 PM
alc2001's Avatar
alc2001
Could it be for a block heater (RPO K05)?
Old Aug 15, 2002 | 12:07 AM
redriverjohn's Avatar
redriverjohn
If your car has dual zone a/c, it could be the outside air temperature sensor. However, if that were the case, your a/c would no be working properly.
Old Aug 15, 2002 | 12:25 AM
0Kaley@DragonRace
Supporting Vendor
Default Re: What is this???? (redriverjohn)
I think it might be the under hood light. I can't remember but I don't think it works
Old Aug 15, 2002 | 05:53 PM
movinup's Avatar
movinup
See if your horn works. It's in the vicinity.
To What is this????
