benelliwang,
Has your car been tuned for your mods??(i.e. your heads/cam, etc...) What about a full cat-back exhaust and off road x-pipe?? Just suggestions! :cheers: :seeya :D
I have lt headers, high flow cats, x pipe, and stock muffler with A&A exhaust mod. I dont wont to change muffers cause it sounds really good now and it is a sleeper. :yesnod:
It was dyno tuned, and has a black wing. I have Vararam sitting in the garage I could put in.
I am missing the following mods:
LS6 intake: I think this should definitely help.
Ported Throttle body: I am not so sure if this will help.
Ported MAF: Again, I am not sure if this helps neighter.
Basically I am trying to get to 400 normally aspirated HP with minimal $.
Also, my rpm is set at 6.5k max. Should I bump it up to 6.7k?
I was going to recommend the LS6 intake, as you have that on the list do it. I think TB and Mass Air will help as you have already done heads & cam.....
For the H&C guys, did you notice any gain from ported throttle body or is it waste of money? How about those ported MAF's? I already have plastic MAF ends.
