Window won't roll down and Headlights Dim
Old May 13, 2015 | 02:42 PM
slick4225's Avatar
slick4225
Default Window won't roll down and Headlights Dim
I tried to roll down the passenger window last night and nothing happened. I did notice that the headlights dimmed when I pushed the button down. I tried from both driver and passenger side switch and got the same thing. I believe the motor must be locked up, and I didn't hold it long enough to pop a fuse or relay. I was just looking for some insight on what you guys think. It did work last weekend just fine. I did read on some of the forms that the brushes stick sometimes and to slam the door while holding the button...however I would like to fix it the right way and not just beat on it until it works. Any insight before tearing the door panel off would be appreciated.
Old May 13, 2015 | 03:12 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Look here, credit 73Corvette with the help
https://www.corvetteforum.com/forums...t-working.html
Old May 13, 2015 | 05:36 PM
73Corvette's Avatar
73Corvette
Don't credit me... all I did was copy and paste someone else's thread that had good solutions to help other forum members fix their C5's...
Guys like Bill Curlee, dadaroo, 8vette7, and a long list of other very bright guys are the ones that deserve the credit...
Old May 13, 2015 | 06:10 PM
beboggled's Avatar
beboggled
Pull off the door panel and take a look? See if the gear is trying to move or not? You might be able to manually wind it down from inside
Old May 14, 2015 | 10:57 AM
dadaroo's Avatar
dadaroo
This should help on removing the door panel if you have never done it.
Old May 14, 2015 | 02:30 PM
Trios's Avatar
Trios
I have had this happen when I don't use the window in months. Slamming the door real good while holding the window down button fixes it for another few months.
To Window won't roll down and Headlights Dim
