Comp Pro. Magnum install help LS-6
Installation
Installation is easy, if you take your time. One very important step is to place the new rocker arms into position to make sure they don't hit the head casting. This is a really serious problem with some aftermarket rockers.
The really good rocker arms use a stud and nut to hold them in place. They also use pushrod guides to keep the pushrods in place.
The real trick is to tighten the nut on the rocker arm stud down far enough-but not too far. The LS engines all use zero valve lash. In the old days we used to tighten our small-block rocker arms down until we could no longer rotate the pushrod. On LS engines you can't even reach the pushrods. D.J. Racing has developed a little time saver here: a 0.001 feeler gauge. After rotating the motor until the appropriate valve is closed, tighten the rocker nut down until the feeler gauge is tight. The difference between 0.001 inch and zero is negligible.
Take your time and make sure everything is just right. If you get this wrong you could push a valve into the top of a piston-at 6,000 rpm. You don't have a lot of clearance to work with. Be careful.
Changing rocker arms won't give you that magic 50 hp that you see in the ads. It should give you at least 20 though, after about a day's work. Even if it takes you the whole weekend, that's no big deal. A weekend in your garage is far better than a day at work.
Read more: http://www.superchevy.com/how-to/cor...#ixzz3abx9hwcj
Follow us: @SuperChevy on Twitter | SuperChevyMag on Facebook
I'm an old school guy as well. Swapping cams in our old Gen 1 small blocks is a piece of cake compared to the newer stuff...
