Key fob not unlocking driver door
Old May 26, 2015 | 10:02 AM
mmf01's Avatar
mmf01
Default Key fob not unlocking driver door
My key fob with lock and unlock the passenger door but not the drivers side. Any ideas on what to look for? Thanks in advance for any help.
Old May 26, 2015 | 10:55 AM
dadaroo's Avatar
dadaroo
Can you lock and unlock the door with the switch on the door?
Old May 26, 2015 | 01:03 PM
mmf01's Avatar
mmf01
Yes. The switches inside work fine for both sides.
Old May 26, 2015 | 05:21 PM
ETPhoneHome's Avatar
ETPhoneHome
like 8vette7 said it is the relay in the door. very easy to change even with very little soldering knowledge.
Old May 26, 2015 | 06:02 PM
73Corvette's Avatar
73Corvette
I'm guessing the reason dadaroo asked his question is that IF the switch is working it's probably NOT the relay...but, I'm am still learning about all this high tech electronic stuff.
Old May 26, 2015 | 09:55 PM
73Corvette's Avatar
73Corvette
Well, if he hasn't drank too much beer today , maybe in the morning he'll shed some light on the shrouded mystery question...lol
Old May 27, 2015 | 07:47 AM
dadaroo's Avatar
dadaroo
The same relays are activated by the switch and the FOB. So we know they are good and obviously the motor which locks and unlocks the mechanism is working.
So it would appear that there is some issue with the door control module itself or in the serial bus circuit to the door. I really doubt that there is any issue in providing the signal from the BCM.
OP, pull your dash DIC codes and I am sure you will see an issue related to this.
Most likely it is in the connection at the door inside the A-Pillar. It can be reached by pulling back on accordion boot and inspecting the connections at that connector. Common issue among the C5s.
Here is a link to help. Take a look at the 2nd, 3rd, and 4th pictures.
https://www.corvetteforum.com/forums...-there-is.html
Old May 27, 2015 | 08:14 AM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
Just to be different I'm going to say that if the switch did NOT work then the relays are possibly OK but the motor for the lock is likely what is bad. I'm sure he will correct one of us................
Or, he may correct both of us...
Old May 27, 2015 | 08:51 AM
dadaroo's Avatar
dadaroo
As you guys know, it isn't about being correct but getting thorough input on an issue. Many times I have forgotten to suggest things others have.
Performing diagnostics at a distance is always challenging. Especially since only a few of the OPs have any experience with electricals.
Old May 27, 2015 | 09:09 AM
73Corvette's Avatar
73Corvette
Sometimes staring at the Forest you just forget to look at the Trees...
Sorry OP... back to your issue
As dadaroo stated:
https://www.corvetteforum.com/forums/...-there-is.html
Old May 27, 2015 | 09:34 AM
dadaroo's Avatar
dadaroo
OP, the serial bus wire in the connector should be Brown. The only one that is that color.
It should be that way for all years. I can verify for your year if you tell me.
Old May 27, 2015 | 09:38 AM
dadaroo's Avatar
dadaroo
Here we go with the bad links again. Doesn't work when I click on it......... Did you try it after you posted it?? Looks like you copy/pasted from a post rather than replying to the post first to be able to get the full link...
Chuck, I just tried accessing the link from my post above. It works for me. Try a little later and let us know.
OP, if you can't get to the link, I can send you the pictures.
Old May 27, 2015 | 10:02 AM
73Corvette's Avatar
73Corvette
Doesn't work for me either...
Old May 27, 2015 | 11:08 AM
mmf01's Avatar
mmf01
I couldn't get the link to work either.
Old May 27, 2015 | 11:17 AM
73Corvette's Avatar
73Corvette
This one works for me... try it
Old May 27, 2015 | 01:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 73Corvette
I'm guessing the reason dadaroo asked his question is that IF the switch is working it's probably NOT the relay..............
Sam, your link in this post is working for me.
Old May 28, 2015 | 07:14 AM
dadaroo's Avatar
dadaroo
Thanks for the help guys.
To Key fob not unlocking driver door
