Torque specs needed
Old May 30, 2015 | 11:04 AM
dogboy's Avatar
dogboy
Default Torque specs needed
Anyone know the torque spec for replacement of starter motor bolts & head exhaust manifold bolts?
Old May 30, 2015 | 11:18 AM
b_rad!'s Avatar
b_rad!
Starter bolts are 36 ft lb
Exh Man Bolts are:
1st pass - 11 ft lb
Fin pass - 18 ft lb
Old May 30, 2015 | 01:56 PM
Patches's Avatar
Patches
FYI - here's a link to LS1/6 torque spes on my website.
C5 Torque Specs
Old May 30, 2015 | 02:47 PM
dogboy's Avatar
dogboy
Thanks guys for the quick response. This is why I think this is one of the best forums going.
Old May 31, 2015 | 05:27 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I have a question on the lower control arm ball joint stud torque.
1st pass 15 lb/ft
2nd pass 210 deg
final pass 52 lb/ft
What does 2nd pass mean?
Old May 31, 2015 | 06:56 PM
ZZ06's Avatar
ZZ06
1st pass 15 lb/ft
2nd pass 210 deg
final pass 52 lb/ft
It is referring to angle measured in degrees on a torque angle meter. Can be performed via torque wrench or breaker bar depending how you wish to proceed. Get yourself an angle guage.
To Torque specs needed
