MGW Shift Knob Report
Old Aug 16, 2002 | 10:59 AM
Tracy's Avatar
Tracy
Default MGW Shift **** Report
We've been discussing the rattling of Hurst (and Kirban and Ripper) shifter for the past several weeks. I managed to quiet down my *second* Hurst (they replaced the first one) with the usual tricks (back off stop bolts, lead weights, etc.). The shifter itself was quiet as an oyster, but when I put the stock **** on.......bzzzzzzzzzzzzzzzzzzzzzzzzzzz.
So, after careful consideration of the MOMO ***** and all the others out there, I decided to go with the MGW "Gripper" piece. You can see it at mgwltd.com
S I L E N C E. Finally. This is a very fine ****, beautifully made. It screws wwaaayyyy down on the shaft, and locks in place with a strong setscrew. I choose the grey anodize, and it looks good and understated (and the finish matches Z06 wheels exactly, FWIW). The "leather" wrapping, which is acutally the same as that synthetic stuff that gets molded to motorcycle handlebars, is very nice and 'grippy'. The ball is not big....but just right for the hand. Heat transfer from the driveline tunnel is what could be expected, warm but not hot to the touch, and the wrapping allows you to shift without having to really grab the aluminum, should the **** be hot from sitting in a closed car on a killer hot day after you've driven it.
Anway, I give the MGW Gripper **** a 10. But...they warn you....it won't stop the rattling in a shifter that has a problem, but it won't contribute to the problem, either. Isn't it bizzare that the stock **** (whci I would have preferred to use, acutally) can vibrate at the threads?
[Modified by tracy, 11:27 AM 8/16/2002]
Old Aug 16, 2002 | 11:27 AM
AFVETTE's Avatar
AFVETTE
Default Re: MGW Shift **** Report (tracy)
Tracy - Same story here. I just installed the MGW Gripper (triple chrome plated) to match my chrome Z06 wheels and all the rattles and buzzing have stopped. As a bonus since this **** screws down even further than the OEM or momo I had it's even lower. The throws are precise but not overly stiff. The Hurst now performs like I expected it to in the first place.
All I can figure is there must have been some natural harmonic vibration with the OEM and momo *****. Probably just enough difference in the mass of the two ***** to change the frequency of the vibration.
In any event the MGW (for $45) is a fantastic piece. Since it screws down about 3/4 of an inch lower than the OEM I would hope folks with the OEM shifter would give it a try. It may make the OEM more enjoyable for little $$$
Tom
USAF Retired
Old Aug 16, 2002 | 11:28 AM
CRUZMISL's Avatar
CRUZMISL
I told you MGW makes some kick butt ***** :yesnod: :yesnod: :yesnod:
Old Aug 16, 2002 | 11:39 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: MGW Shift **** Report (CRUZMISL)
:confused: Why no pics??????? Let's see your ***** :smash:
<edit on> found a pic.......sweet!<edit off>
[Modified by Mag Red Monster, 9:44 AM 8/16/2002]
Old Aug 16, 2002 | 11:58 AM
rpoz06's Avatar
rpoz06
Default Re: MGW Shift **** Report (Mag Red Monster)
Here's the other **** they offer. Available in chrome also. I like them both. I have a Hardbar but I really thinking about changing to this one.
[Modified by rpoz06, 9:59 AM 8/16/2002]
Old Aug 16, 2002 | 11:59 AM
chuckster's Avatar
chuckster
Tracy, the reason the stock **** os soooo noisy is simple...
The top of the stock **** is hollow. Therefore allowing the end of the solid metal shift rod to be exposed. The only thing on top of it is a plastic cap.
The whole thing acts like a mechanics stethescope. It transmits all the tranny noises right up to the plastic cap that acts like a frigging speaker. :D
I found this out by putting my palm over the cap and everything went silent..
I have since pulled the cap off and filled it with silicone bathtub sealant. That does a great job of silencing the dreaded stock ****. :smash: :smash:
Old Aug 16, 2002 | 12:26 PM
Tracy's Avatar
Tracy
Default Re: MGW Shift **** Report (chuckster)
chuckster--my **** rattled with the shift pattern insert piece was in my garage and my car was 20 miles away! :D And this is with and without the T-pin. I have tried ALL the tricks to quiet the stock ****..teflon tape, silicone, screwing down ultra tight, etc etc etc. The damn thing even buzzed when I had my hand on it. Hell, I drive with my hand on the shifter anyway, so you'd think that would solve the problem. As AFVETTE mentioned, the Hurst likely transmits a vibe at the natural frequency of the ****, and there's no way to dampen it. The Kirban in my 2000 buzzed the **** a little bit at a narrow rpm band, so I could live with it.
The MGW solved the problem on the Hurst.
I have held and played with their other ****, the cylindrical one that zpoz06 shows, and it's also beautifully made, but I prefer the ball style for "palm of hand" shifting.
My post is not a knock on any of the MOMO *****....I love the styling of the Combat/Phantom/F16 *****. But I've heard reports of some of them buzzing like a cicada, and I didn't want to take a chance.
[Modified by tracy, 11:43 AM 8/16/2002]
Old Aug 16, 2002 | 12:39 PM
Disco Stu's Avatar
Disco Stu
Thanks for the info; i was about ready to rip my hurst out. I will give the **** a try
Old Aug 16, 2002 | 12:44 PM
Tracy's Avatar
Tracy
Default Re: MGW Shift **** Report (tbrewing)
I was, too. That stock POS shifter was beginning to look better and better, sitting there on the workbench, all nice and quiet.
Hurst should kiss MGW's feet.
Old Aug 16, 2002 | 01:36 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
There is no reason to pull a Hurst shifter! From all I've seen it is the **** that is the culprit. I have no rattle with a MOMO Combat Silver, no "wheel weights", etc. The only thing I'm considering is a little insulation wrapped around the shaft to hold down heat and some minimal noise.
Old Aug 16, 2002 | 02:34 PM
gbm's Avatar
gbm
:D
Old Aug 16, 2002 | 02:39 PM
Disco Stu's Avatar
Disco Stu
Default Re: MGW Shift **** Report (gbm)
Just ordered mine. Can't beat $45.
:cool:
Old Aug 16, 2002 | 02:51 PM
Tracy's Avatar
Tracy
Yeah, I didn't really mention it or focus on the cost, but $45 (plus $7 shipping) is really an excellent deal, considering what the MOMO's and other ***** cost, and then considering the extreme quality of this MGW item. It even comes nicely boxed. cushioned and protected, AND they provide the Allen wrench to tighten the setscrew. :cheers:
Old Aug 16, 2002 | 03:13 PM
jimman's Avatar
jimman
Thanks dude I'm going to give it a try, this rattle is diving me nuts.....
[Modified by jimman, 1:13 PM 8/16/2002]
Old Aug 16, 2002 | 03:14 PM
gmblack3's Avatar
gmblack3
I have the MGW **** as well. I still have my stock shifter and it feels much better without the stock ****.
Old Aug 16, 2002 | 03:22 PM
jimman's Avatar
jimman
Default Re: MGW Shift **** Report (jimman)
missed it, where do I get these *****? :confused:
Old Aug 16, 2002 | 03:25 PM
Disco Stu's Avatar
Disco Stu
http://www.mgwltd.com
To MGW Shift Knob Report
Old Aug 16, 2002 | 03:29 PM
jimman's Avatar
jimman
:D
Old Aug 16, 2002 | 05:50 PM
gbm's Avatar
gbm
No one will be dissapointed!!!! no rattles no buzzes no nothing
CRUZMISL was right! THANKS!
:jester
Old Aug 24, 2002 | 09:50 PM
jimman's Avatar
jimman
It frikken works, can't believe it and don't care, no buzzzzzzzzzz finally piece.
