PCM Code 1571 - ASR Desired Torque
Old Aug 16, 2002 | 11:20 AM
scool93535's Avatar
scool93535
Default PCM Code 1571 - ASR Desired Torque
Does anyone know what this means? Is the engine not making the torque it should or is it exceeding the expected torque?
Silver 97 w/ Vortex ram air, power duct, GMAF.
Old Aug 16, 2002 | 02:16 PM
weaver's Avatar
weaver
Default Re: PCM Code 1571 - ASR Desired Torque (scool93535)
This is a signal from the Electronic Brake and Traction Control module, which will change if a Traction Control event occurs, to ask for reduced torque from the engine. The code being set means that the Power Control Module did not recieve this signal for 3 seconds.
Mark
Old Aug 16, 2002 | 02:29 PM
scool93535's Avatar
scool93535
Default Re: PCM Code 1571 - ASR Desired Torque (weaver)
Thanks. Any idea if this is set by turning on or off the traction control?
Old Aug 16, 2002 | 03:29 PM
weaver's Avatar
weaver
Just turning the Traction Control on or off wouldn't set the code. I wouldn't think you'd ever see the code if the Traction Control was off, however.
Mark
Old Aug 16, 2002 | 03:53 PM
scool93535's Avatar
scool93535
Thanks. I did leave it on while driving home form work yesterday and, managed to cause the TCS to kick in going around a yeld lane. Thanks for the feed back.
To PCM Code 1571 - ASR Desired Torque
