Wire harness replacement located behind battery
Old Jun 2, 2015 | 04:02 PM
YocumVette's Avatar
YocumVette
Default Wire harness replacement located behind battery
I was swapping out an old battery for a new one and noticed a rodent had chewed and broken a few wires on the wiring harness that runs behind the battery shelf. This harness appears to have 50+ wires in it. Does anyone know what this harness controls, what it is called, and how much it might cost? Can this novice DIY'er do this job? I wonder if this could be the reason I have a few codes popping up on my instrument panel.....?.
Thanks for reading!
Old Jun 2, 2015 | 04:05 PM
YocumVette's Avatar
YocumVette
My Vette is a 1997
Old Jun 2, 2015 | 04:17 PM
4DRUSH's Avatar
4DRUSH
Yocumtown, Pa ?
Old Jun 2, 2015 | 04:44 PM
YocumVette's Avatar
YocumVette
Originally Posted by 4DRUSH
Yocumtown, Pa ?
I've been to Yocumtown, PA and my dad's folks were from PA, but he moved to Mississippi and that's where I was born and raised.
Old Jun 2, 2015 | 04:48 PM
Trios's Avatar
Trios
If it's just a few wires, I'd splice them together with some solder & heat shrink. If it's more than a few wires....good luck, man. Replacing that harness is going to be a real PITA.
Old Jun 2, 2015 | 04:52 PM
YocumVette's Avatar
YocumVette
You're probably right. From what I can tell, it's only 3 or 4 wires!
Old Jun 2, 2015 | 11:03 PM
junk c5's Avatar
junk c5
I believe that's the same harness I just had repaired in my 1999. Seems like harnesses are very particular for each year and model with their specific options. That harness goes into the PCM and controls most of the sensors under the hood. If it's just a few wires, I'd repair them yourself. If it needs harness ends or lots of help, I'd reach out to Marc at vettenutts. He repaired my harness in a timely manner and I found it to be a better option than rolling the dice on another harness.
Old Jun 3, 2015 | 09:01 AM
TOPCATHR's Avatar
TOPCATHR
TRIOS is giving good advise...use solder and shrink tubing not crimp connectors.
Old Jun 3, 2015 | 11:22 AM
YocumVette's Avatar
YocumVette
Thanks for all the replies! Now I have to add this to my "roudtuit" list!
To Wire harness replacement located behind battery
