Key Fob
Old Jun 3, 2015 | 04:52 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Key Fob
key fob stopped working-put in a new battery and it worked for a day with standard "two button" start...then stopped....reset again and it worked....did the "DIC" reset and it worked...then stopped...two button reset...it worked for an hour and quit....what is going on with it???..don't know if it is the fob or the car!!!
Old Jun 3, 2015 | 08:43 PM
65GGvert's Avatar
65GGvert
If you're not going to fill out your profile, you should put the year of your car in any question. I suspect you have a 2000, because there have been many, many 2000 fobs posted on here with the exact same symptoms. The link 8vette7 posted will fix a lot of them, but if it fails you'll need to buy another one, and the 2000 fob ain't cheap. Check with Cultrag if you need one.
