Problem with Fan Control Switch
Old Jun 4, 2015 | 06:09 PM
kirtp's Avatar
kirtp
Navigator
Default Problem with Fan Control Switch
I tried searching this topic but couldn't find anything. If you've run across this problem point me in the right direction. Thanks!
On my C5 the AC, Heater, Rear Window Defog all work but there are times when the switch won't work so they won't turn on and the fan won't work. At times I can smack my fist against the side panel by the switch **** and it will work but that's not always successful. Any suggestions?
Old Jun 4, 2015 | 07:00 PM
kirtp's Avatar
kirtp
Navigator
Originally Posted by 8VETTE7
Manual control or Climate control on the HVAC?
Manual control....
Old Jun 5, 2015 | 12:03 PM
kirtp's Avatar
kirtp
Navigator
There is a resistor pack that provides the various speeds for the fan. Common C5 failure is that the resistors fry. Replacement resistor pack is available from many parts store and if you are very rich from the Stealership also....
Thank you for the info, I'll check that out.
To Problem with Fan Control Switch
