seat memory problems
Old Jun 4, 2015 | 09:02 PM
jon reed's Avatar
jon reed
Default seat memory problems
when I use my fob the memory sets everything to the previous owner. the memory switch doesn't light up and I don't think it is working. does it have a fuse? and is there a way to keep the settings for me when I use the fob if the switch isn't working. in other words nothing move when I use the fob. 99 corvette
Old Jun 4, 2015 | 10:44 PM
jon reed's Avatar
jon reed
Default memory
Originally Posted by 8VETTE7
Have you pulled the door panel to see if the cables are connected?
No you cannot set the memory EXCEPT with the switches on the door.
Lots of info in the Owners Manual on how the memory works.
Don't have one?
Try here:
http://www.1997-2004corvettes.com/19...rs-Manual.html
Download is free...............
yes I checked the cables and yes I have a manual. I have comm with the left door control module . it must be the switch itself. thanks for your input.
Old Jun 4, 2015 | 11:33 PM
jon reed's Avatar
jon reed
Default memory
Did you pull the codes to see if there are any LDCM DTC's???
Memory switch faults may be listed there. B2242 and B2244. Might be other related codes as well.
OR
http://www.c5forum.com/ayc/dtcdic.php
im one of the lucky ones that has no codes except for no radio comm. because I have an aftermarket unit
Old Jun 5, 2015 | 02:27 PM
sweetbeard's Avatar
sweetbeard
Whenever I lock my car with the FOB when I start it back on it forgot my settings and the AC is on....
way annoying
Old Jun 5, 2015 | 03:17 PM
sweetbeard's Avatar
sweetbeard
Indeed...
Old Jun 5, 2015 | 05:52 PM
jon reed's Avatar
jon reed
Default memory
Originally Posted by sweetbeard
Indeed...
how can it be operator error if the switch isn't working?? maybe you know something I don't.
Old Jun 5, 2015 | 06:08 PM
jon reed's Avatar
jon reed
Default please read the question
is there a fuse just for the memory and is it possible to unlock the car with the fob and the memory not default to previous owner. the switch does not light and may not work?
Old Jun 5, 2015 | 07:26 PM
grantv's Avatar
grantv
So you set the DIC to have easy exit and entry on? You put your seat where you want it then held down the #1 button on the door until it blinked after opening with FOB #1? You're using a factory FOB? Sorry if I missed anything, on my phone getting my hair cut.
Old Jun 5, 2015 | 07:33 PM
jon reed's Avatar
jon reed
Default not even close?
people please read the question.
To seat memory problems
