memory
Old Jun 4, 2015 | 11:09 PM
jon reed's Avatar
jon reed
Default memory
does anyone know which plug goes to the memory that comes out of the ldcm. or a way to test the switch. it doesn't light and doesn't seem to work. I had the car painted in December and it worked before It was painted. they took off the mirrors so they may have unplugged it. ive had the door panel off and didn't see anything unplugged. also is there a fuse just for the switch?
Old Jun 5, 2015 | 07:35 AM
dadaroo's Avatar
dadaroo
Left door Memory is maintained in the module like the right door and the seat. There is a serial bus wire that goes to the BCM from each module.
You said you have the FSM so you have the schematics and connector views to test the switch.
