Need help with some code.
Jun 9, 2015 | 11:03 AM
Check engine light just came on.
These are the codes.
10-PCM P0440 H C
60-IPC U1160 H
99-HVAC B0361 H C
B0441 H
Jun 9, 2015 | 11:35 AM
Your CEL is related to the EVAP system. I can post the full code information for you but you failed to provide us the year of your car.
Try clearing everything and see what comes back.
I think the other C code is an actuator issue. Not at home but there is a simple recal attempt you can do to see if it helps.
Jun 9, 2015 | 03:25 PM
Quote:
Originally Posted by
8VETTE7
OP's profile indicates a 2001 Z06........
Roger 01 Z06
Jun 10, 2015 | 06:33 AM
Here is the actuator re-cal info, I will provide the EVAP info a little later and then anything else you need after that.
Re-Calibrating Actuators
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module (fuse #27).
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
Jun 10, 2015 | 07:03 AM
Jun 13, 2015 | 03:17 PM
I can't get that Dropbox format to open. Do you have it in any other format?
Jun 13, 2015 | 05:22 PM
Send me a PM with your email address and I will send it directly to you. Just make sure you tell me what you want so I know. I deal with a lot of requests.
They are PDF so you need Adobe reader. Free download it you need it.
