I need to replace sway bar end links
Old Jun 9, 2015 | 02:16 PM
xdmikey's Avatar
xdmikey
Default I need to replace sway bar end links
Should I cough up the extra cash and replace the bars themselves as well?
Things are tight right now.
Thanks.
Old Jun 9, 2015 | 04:02 PM
Cybermind's Avatar
Cybermind
Unless you want to go to bigger bars, there is no reason to replace the swaybars. They will last the life of the car. Just go ahead and replace the endlinks.
Old Jun 9, 2015 | 04:36 PM
xdmikey's Avatar
xdmikey
Default Thanks Cyber
The future of the car is up in the air right now so this helps a bunch!
Old Jun 9, 2015 | 04:55 PM
jamieo's Avatar
jamieo
May want to check the sway bar bushings while you're in there.
Old Jun 10, 2015 | 12:25 PM
xdmikey's Avatar
xdmikey
My links are in pieces, minus some I'm sure!
I also think this may cure my clicking from the front end. I jacked one side, spun the wheel and no sound and no "keepers" on the wheel studs. I moved past the rotor and looked for the "links" and they were barely together.
Just passing that along.
Old Jun 11, 2015 | 05:20 PM
racebum's Avatar
racebum
get the 02+ z06 links, they are metal and very reliable
bushing wise. new OE or energy suspension
To I need to replace sway bar end links
