Brightest LED brake light bulbs?
Old Jun 10, 2015 | 08:55 AM
turbo1248's Avatar
turbo1248
Default Brightest LED brake light bulbs?
I have dark smoked tail lights in my C5 Z06 and I need the brightest LED bulb available...any suggestions from experience?
Thanks so much in advance!
Old Jun 10, 2015 | 10:03 AM
3sACROWD's Avatar
3sACROWD
I have CREE high power RED LED lights in my car. I believe they are 30W. I have tinted (appear dark cherry up close and almost black at a distance) lenses and you can tell when my lights are on during the daytime. The brakes are almost blinding. With stock bulbs, you really couldn't tell running lights were on during the day.
Make sure you buy RED LED lights. They claim the red color helps the light project through the red lense.
I'll warn you in advance that you will likely get RF interference in the radio when applying the brake or turn signals. I'm looking at options to shield the antenna and / or light housings.
Not sure if the link below will show up or work. This is what I bought.
http://www.ebay.com/itm/2x-30W-Red-6-Cree-XB-D-High-Power-Led-3157-3156-4157-Tail-Bulb-Brake-Stop-Light-/331111550658?hash=item4d17c94ec2&vxp=mtr
Old Jun 10, 2015 | 10:16 AM
turbo1248's Avatar
turbo1248
2X 30W Red 6 CREE XB D High Power LED 3157 3156 4157 Tail Bulb Brake Stop Light | eBay
Just bought 2 pairs, thanks very much for your help!
Old Jun 10, 2015 | 10:35 AM
3sACROWD's Avatar
3sACROWD
Do not reinstall the tail lights until you verify the bulbs are working. They seem to have a polarity to them. If the light doesn't work, pull out and rotate 180 degrees, then reinsert.
You will also get hyperflash if you don't have a hyperflash harness or use some sort of resistor.
Old Jun 10, 2015 | 02:18 PM
turbo1248's Avatar
turbo1248
Thanks again
To Brightest LED brake light bulbs?
