I think I have a Microsoft version PCM .....
Old Aug 16, 2002 | 11:48 PM
JWSchmidt3's Avatar
JWSchmidt3
Default I think I have a Microsoft version PCM .....
I pull up to my garage today, and as I'm waiting for the door to lift, my DIC starts flashing "Reduced engine power" and "Service Traction Control", while at the same time, my T/C light is displayed like I had turned it off. :confused: So I limp the car into the garage (reduced power mode), and try to clear the codes with the car still running. No go, as I have a current code in 10-PCM & in 20-TCS. So, I turn the car off, cycle the key (without starting), clear all my codes, and turn the key off. I wait about 10 seconds, stick the key in, cycle the gauges, and she fires right up. Went out, drove about 30 miles, and all is good. Guess it just needed a good "re-boot". :lol: Now, if I can just get the damn PIAA fogs to quit blowing fuses, I'll be happy. :cuss :mad Starting to look like I need a new beater, and hand this one over to the wife. :D
Old Aug 16, 2002 | 11:54 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: I think I have a Microsoft version PCM ..... (JWSchmidt3)
What codes did you clear?
Old Aug 17, 2002 | 12:08 AM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: I think I have a Microsoft version PCM ..... (66ImpalaLT1)
I knew someone would ask that. All of them. ;)
I looked at what they were, but forgot. :crazy: It's fixed, but if it does it again, I'll be in less of a hurry and write them down and look them up. :cheers:
Old Aug 17, 2002 | 12:16 AM
Hissey's Avatar
Hissey
Been there!!! I think GM needs to give us a freaking interface when we buy these cars. Like LS1 edit but better. It is extremely annoying when your car goes hay wire and the motor is prefectly fine. Just my .02$
Old Aug 17, 2002 | 12:35 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
John, keep your eyes peeled for voltage problems. Worth a peek in the passenger footwell for dampness too.
Old Aug 17, 2002 | 12:56 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Been there about 3500 miles ago *Gremlins* lit up my DIC and it went away in about 20 seconds and not one problem since then :smash: :smash:
Giving your wife your coupe huh :cuss :cuss ;)
Old Aug 17, 2002 | 03:29 AM
bparker's Avatar
bparker
Thats funny as SHEET!
As for the PIIAs - I was popping fuses and bulbs for a while until I called them and pitched a bit - and they sent me a new updated relay and I havent had a problem since.. U might want to call them and inquire about your relay version as well - :cheers:
Old Aug 17, 2002 | 12:55 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: I think I have a Microsoft version PCM ..... (bparker)
yeah the relay may be the culprit on the fogs :yesnod: (good call bp :D )
car could have a loose ground somewhere too that is cauzin the gremlins :confused: ...... time to drop that beyotch at COH and let that warranty work for ya brudda :)
thanks
Old Aug 17, 2002 | 03:18 PM
JWSchmidt3's Avatar
JWSchmidt3
That's what I was thinking. I replaced the 10 fuse with a 15, and it still popped. Just got these though, I would figure they'd replaced the relays by now. Oh well, I'll fire off an email to PIAA, and have COH check the ground next time I'm home. :cheers:
Old Aug 17, 2002 | 03:21 PM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: I think I have a Microsoft version PCM ..... (MilYellow02)
Joe, I sense a lot of anger bro. You need to let it all out. :smash: :D :p: :lol: Yup, the wife gets the old, I get the new. :cheers:
To I think I have a Microsoft version PCM .....
