Exhaust leak?
Old Jun 18, 2015 | 09:23 PM
bwill03z's Avatar
bwill03z
Default Exhaust leak?
Is there any way to check to see if I have an exhaust leak without raising the car? I dont have a lift or jack. I recently had a shop weld my stock cats back on and I believe i may have a leak in that area... sounds kinda fluttery under throttle.
Old Jun 19, 2015 | 02:17 PM
RedZMonte's Avatar
RedZMonte
i have allways check from under with your hand, car running see if you can feel the exhaust puffing out a hole..
Old Jun 19, 2015 | 02:39 PM
rodsvet's Avatar
rodsvet
Take it back to the shop that did it and ask them to double check. Any reputable shop will do it. Only takes them 5 minutes.
Old Jun 20, 2015 | 07:19 PM
bwill03z's Avatar
bwill03z
Is it ok to put some rags inside the tips the force extra exhaust out of any leak? Ive heard of doing this but didnt know if any damage could be done.
Old Jun 20, 2015 | 11:07 PM
Dcollins3208's Avatar
Dcollins3208
Sea foam it
Old Jun 20, 2015 | 11:34 PM
bwill03z's Avatar
bwill03z
Originally Posted by Dcollins3208
Sea foam it
Why Sea foam it?
Old Jun 20, 2015 | 11:55 PM
Dcollins3208
The smoke will come out of wherever the leak is, but if you can just raise the car and feel around that'd be much better
To Exhaust leak?
