Big cam bad initial idle every time
Mods: Longtubes; no cats; Magicstick 4 cam kit & custom tune from TSP
Problem: Every start is rough and sometimes dies
Cam: http://www.texas-speed.com/p-1153-te...-camshaft.aspx
Tune: Mail order from Texas Speed for my setup & cam
UPDATE: After good forum feedback I will be taking it to get a custom tune @ West Bend Dyno in Wisconsin. I will post additional updates next weekend
VIDEO - hot start, no throttle, no AC, 74*F ambient:
What I've tried so far: Checked for vacuum leaks 4 times (engine running +felt for leaks). Removed and checked entire intake system for holes or lose clamps. Checked MAF & Throttle Body - clean and undamaged. Checked DIC error codes - No PCM codes (only some traction and abs codes). Checked every electrical connection I find. Finally called TSP for advice, they want me to mail back the PCM for re-tuning.
Detailed problem: Every time the car is started the car has a hard time idling and sometimes dies but after about 15 seconds will adapt and then will run OK from then on most of the time. Outside temp doesn't matter, car can be cold or hot - every start even repeated starts after good idle is attained. Clutch starts or neutral starts doesn't matter. Using throttle helps but takes much longer to attain good idle (1-2 minutes sometimes). Sometimes while driving car will not come to an idle and battles to keep running at stop lights (usually when car is stopped). Sometimes when shifting up will also nearly stall. Also there is a pretty heavy fuel odder from the exhaust after every start, might be OK since no cats. Oh and if I try to start it with the AC running it dies every time without some good throttle.
My thoughts: I know it is a huge cam and expect rough idles and some cam surge, but this is not normal - I've had LT1's with cams almost thing big and didn't have any idle issues at all. I spoke with TSP and they just thought to check for vacuum leaks otherwise send PCM in for re-tune, I want to save this as a last resort since it causes long downtime and really don't see how they could have miss-tuned the startup idle so bad but rest of the tune seems pretty good.
And idle and drive ability is all tune. ( if there is no mechanical problems) Enough time and know how can make a monster solid roller drive like a Buick.
Check the pcv system and if it hooked up correctly. If I read right you are sending the ecu off to be tuned? Mail order stuff is a joke. Go to a good tuner and have them do some street tuning.
Fuel/exhaust smell is part of the game with that kind of overlap and no cats.
I feel much better about going and spending $400+ on a custom tune now. Not sure if i'll get to it this year or not since I may want to do a few more mods over the winter.
I'll probably let this thread go without updating it with the solution if I wait that long to tune it
I talked with Doug at east coast and he said he could do a mail order tune to get my car to a shop for a decent tune, as cam goin in my car won't even start once cam is in, Lg gx3.
Next week I drop my car off @ West Bend Dyno in Wisconsin for a few days of tuning, likely ending in a $650 bill
I am hoping for an end result of 430+rwhp w/ a MS4 cam, CAI, LongTubes & no cats
.Spending this weekend changing spark plugs and going over the car. Will post results next weekend when I get the car back.
Good job checking for leaks - this is always good to do. My car had/has similar issue; needs tune.
One thing I did that helped a lot was to slightly enlarge the idle hole in the throttle body blade. Caution: this is considered 'bad form' and 'shadetree' by many. However it reduced my engine's surge/dying @ stoplights by 80% or more. If you mess up it's a $20 plate, no biggie.
The 'right' way to do it is still a tune.
