HELP ! On a Trip....
Old Jun 21, 2015 | 04:04 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Default HELP ! On a Trip....
I'm on a road trip and have a problem with my passenger window. I think the regulator motor in the door broke, window won't go up without pulling.
Anyway.... since my car is a convertible, any way to put the top down without the windows automatically lowering until I get home?
Could I pull the fuse for the window, lower the top, then replace the fuse? I don't see a fuse just for windows. Is it the door control module fuse?
I don't want stuck with the window down. I have it up now.
Thx
Old Jun 21, 2015 | 04:19 PM
kvozel's Avatar
kvozel
St. Jude Donor '08
Originally Posted by 8VETTE7
You can remove fuse #30 in the passenger foot well fuse box. However none of the other door functions on the passenger door will work. Things like the lock, mirror adjustments, etc.
Nothing easy that comes to mind beyond that.
Thanks, I updated my post took ask exactly that. I could remove fuse, lower tip, then replace fuse after top down. Shouldn't trigger anything, or should i just leave fuse out?
Old Jun 21, 2015 | 05:00 PM
kvozel's Avatar
kvozel
St. Jude Donor '08
Can't answer that with a hand on knowledge response. I would not expect anything strange but you will have to try and see what happens...
To HELP ! On a Trip....
