Daytime Running Lights?
Old Aug 18, 2002 | 08:52 AM
JNP's Avatar
JNP
Default Daytime Running Lights?
If someone could tell me how to get to the right front yellow running light bulb I would appreciate it. I picked up my new car on Friday and either the bulb blew or the train ride out here shook it loose. I really would like to fix it this morning rather than wait till Mon. or Tues at the dealer. Thanks, JNP :seeya
Old Aug 18, 2002 | 10:22 AM
gmblack3's Avatar
gmblack3
Default Re: Daytime Running Lights? (JNP)
If you can get your car up on rhino ramps or jack the front this will be the best way. There are horz. black panels that have 5 screws in them. they are fwd of the wheel well. Remove them and move your brake duct out of the way. You will see the DRL/turn signal bulb sockets right there.
You can also go from the front brake ducts holes by pushing the brake duct down and out of the way. You have to reach in and outbd to get to the bulb socket. If you are not sure where it is raise the hood then the headlites and look down in there to see where they are.
Old Aug 19, 2002 | 02:06 AM
los7883's Avatar
los7883
Default Re: Daytime Running Lights? (gmblack3)
Push back the brake ducts and reach in from there, it's a tight squeeze and you have to fool with it to get it out, but a lot easier than removing the panels IMO.
To Daytime Running Lights?
