Removing Intake Manifold
Old Aug 18, 2002 | 05:41 PM
CP's Avatar
CP
Default Removing Intake Manifold
Does the antifreeze need to be drained or are there no water passages in the heads to the intake manifold?
Old Aug 18, 2002 | 05:47 PM
Bill Reid's Avatar
Bill Reid
Default Re: Removing Intake Manifold (CP)
There are no coolant passages in the intake manifold.
Have you done TB bypass yet? Suppose you could unbolt TB from manifold and let it hang if you are removing the intake if that hasn't been done yet. Why are you removing intake? Upgrading? If your car is Y2K or older then yes, coolant should be drained so that the small coolant pipes can be removed, the rear stops put in, and the new coolant passage pipe installed on the front of the heads...
:cheers:
[Modified by billreid1@***.net, 3:48 PM 8/18/2002]
Old Aug 18, 2002 | 05:54 PM
CP's Avatar
CP
Default Re: Removing Intake Manifold (billreid1@***.net)
My car has the whistling intake and I was wondering about the mess involved. I just had the rings done a couple months ago (4,700 miles a quart :D now ) and am thinking about getting the intake replaced per the TSB.
Old Aug 18, 2002 | 06:21 PM
Bill Reid's Avatar
Bill Reid
ah, Ok... if you are sticking with a same year or compatible intake then, no, you shouldn't have to break into any coolant. :)
To Removing Intake Manifold
