combine chassis grounds?
Old Jun 30, 2015 | 10:02 PM
david_12121's Avatar
david_12121
Default combine chassis grounds?
So my car has 30 or so of those infamous ground related DIC codes. I have cleaned them a bunch of times and it yet throws codes.
Is there any reason to not cut off the connector plug, and connect them all to a single 4AWG wire and attach it to the battery directly?
Old Jun 30, 2015 | 10:06 PM
4DRUSH's Avatar
4DRUSH
I wouldn't go that far, just bunch each group up & connect where they are.
Old Jun 30, 2015 | 10:39 PM
dbgoodwin's Avatar
dbgoodwin
Is there any kind of grounding kit for our cars? There was always stuff like that in the nissan/Infiniti cars. I would be interested because electrical issues are the worst kind of issues.
Old Jun 30, 2015 | 11:47 PM
lionelhutz's Avatar
lionelhutz
Some guys cut the splice packs off and put rings on all the wires and then re-install on the same stud. It's not really necessary to run all the wires back to the battery.
Old Jul 1, 2015 | 01:42 PM
david_12121
I'll try mounting them like that. Guess I can run wires later on if I need to.
To combine chassis grounds?
