DTC P1432 f/p 5v low
Old Jul 10, 2015 | 09:33 AM
coyote35's Avatar
coyote35
Default DTC P1432 f/p 5v low
I have an open circuit on Pcm blue 44 pin which is the 5 V circuit on the right fuel tank sending unit . Trying to figure out where it might be open at anybody have any ideas I ohm'ed out from 44 blue on pcm back to Gray black on right sending unit shows open circuit I don't see anything else on the wire. Does that wire run through the tunnel or inside ?
Old Jul 10, 2015 | 09:28 PM
coyote35's Avatar
coyote35
Default Fuel gauge going to zero p1432
Found broken wire where the right tank pig tail go's down to the sender gray/black
