Lean codes/Cold Air Intake
Old Jul 11, 2015 | 08:04 PM
Bruisr's Avatar
Bruisr
Default Lean codes/Cold Air Intake
On a bone stock C5 from what I reasearched the Black Wing was least likely to throw lean codes than K&N/Varam/Volant etc....I'm look for an upgrade without dealing thus problem. Per vendors that sell CAI's(snake oil) they state that the Black Wing will not throw this code...any suggestions? I know it's not a "true" cold air system like the Varam etc ...just looking for a mild upgrade...
Old Jul 11, 2015 | 11:26 PM
73Corvette's Avatar
73Corvette
I installed the Vararam on our 04 ... not hard to do, just take your time... put the MAF in the STOCK position and DO NOT run the Power Duct...
After you install it, take it for a casual 30 minute cruise and let the PCM make adjustments for the new air... should NOT give you any codes.
I agree with 8vette7 about the LEAKS... mine was used and I called and got all new seals. I didn't want any leaks.
I lost a few MPG's after installing the Vararam... but, got it back and then some after having a Chuck CoW tune done. Back to about 29 MPG on the highway.. and 23 around town. It's a 6 speed.
Old Jul 12, 2015 | 04:06 PM
92GA's Avatar
92GA
Oldtimer
I installed an AfE cai a couple years ago. I sometimes get the lean codes in the fall and spring when the air is real good. Mine only does it if I have driven the car for a while, then park it, then take off again with out letting it run for a bit. It never did this before the mod. It does run better with the mod though.
Old Jul 12, 2015 | 05:44 PM
starfire54's Avatar
starfire54
I installed (2 weeks ago) a Honker (Callaway), which is as close to a true CAI as any and have not had one code thrown. Also very high quality piece.
Old Jul 15, 2015 | 04:31 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thanks VERY much!
Thanks VERY much!
YES, a great tune will always make things right.....And YOU VERY HAPPY!
Call any time.
Chuck CoW
Old Jul 16, 2015 | 03:13 PM
peteinpa's Avatar
peteinpa
Can you explain why one should not run the Power Duct? I recently installed the Vararam B2 w/o the duct and just order the PD was planning install this weekend.
Old Jul 16, 2015 | 04:20 PM
bikeriderga's Avatar
bikeriderga
None of them should throw codes with just the CAI on a stock C5. If you mod the exhaust and then add the CAI, yes probably will throw lean codes.
Old Jul 16, 2015 | 07:28 PM
73Corvette's Avatar
73Corvette
It changes the air flow to the MAF... IF your going to get a tune, you'll be ok. I'm not sure HOW much the PCM can adjust... I had read where others have had some issues when running the power duct and relocating the MAF with codes... BUT, I have no personal experience with it...
If you are really wanting to know more from a technical stand point I would call Chuck and CoW and visit with him... great guy and will have solid answers to your questions.
Old Jul 17, 2015 | 07:36 AM
peteinpa's Avatar
peteinpa
OK gotcha. The guys who work on my car express a similar concern.
Old Jul 17, 2015 | 01:51 PM
Cliff8928's Avatar
Cliff8928
These issues appear to be more prevalent if you have a Z06 (or de-screened) MAF. I was getting the P0171 & P0174 with the Vararam in mine. I'm probably going to swap it for a Halltech with the new style MAF. I'm definitely disappointed in the fit and finish of the Vararam.
Old Jul 17, 2015 | 02:20 PM
Sox-Fan's Avatar
Sox-Fan
I made the swap and love it.
Just a note: If you go to the Halltech with the new style MAF (killer bee II) and have no other mods you're going to have a problem tuning it for low RPM/demands. The larger pipe and the new style MAF will struggle with not enough of velocity/volume across that MAF in that huge intake tube. The Venom II will not have the same issue.
Of course if you have other mods that will help it move more air past the MAF at low rpm/demand then it won't be a problem at all.
I love mine.
To Lean codes/Cold Air Intake
