Column Lock Module Replaced - Now Low Voltage Issues
Old Jul 13, 2015 | 10:05 PM
jzummo1364's Avatar
jzummo1364
2nd Gear
Default Column Lock Module Replaced - Now Low Voltage Issues
I recently had my column lock module replaced due to the infamous column lock fuel cutoff issue....now I am getting a low voltage error and the car delays on start up. Any ideas?
Old Jul 14, 2015 | 07:59 AM
Czarvette's Avatar
Czarvette
Paul Koerner, GM World Class technician and Corvette specialist, says that the #1 cause of the column lock issues is low battery voltage. He's kept records on hundreds of column lock problems that he's worked on, and says over 80% of the time the root cause was a weak battery. The column lock sensor looks for under-voltage.
The fact that you are seeing low voltage issues (with the engine off, right?) confirms a battery problem. The cure is to replace the battery.
Old Jul 14, 2015 | 08:32 AM
Macleod52's Avatar
Macleod52
Or first make sure the battery is fully charged and have it tested to make sure it wasn't bad. It could just be low or have a parasitic drain and just needs a full charge. It would be a shame for someone to spend the money on a brand new battery when all they needed to do was charge their perfectly good one.
Old Jul 14, 2015 | 08:54 AM
radar502's Avatar
radar502
Auto Zone and have it tested ,then leave you night be temped to buy parts or something.. C-5s hate low volts.. Don't be the low volts guy..
Old Jul 14, 2015 | 11:11 AM
dadaroo's Avatar
dadaroo
If they charge the battery and it tests good then we need to see what may be draining it. I doubt it is an alternator issue not charging it.
Old Jul 14, 2015 | 12:07 PM
jzummo1364's Avatar
jzummo1364
2nd Gear
Thanks for the replies - I called the dealership where I had the module replaced and they asked me to bring it back in for their tech to look at it again. Good grief.....
Old Jul 14, 2015 | 12:15 PM
Macleod52's Avatar
Macleod52
I would see if you can have them remove it and refund your money (assuming you're talking about the lock mechanism itself). The locking mechanism will fail and you will want to buy an LCM5. No matter what the dealer says the column lock issue was never fixed, even with the various recalls. If you do a search on here for LCM5 you can see all the in-depth discussions about it.
I know this isn't helpful to solving your issue but if you can get your money back and spend a fraction of it on the LCM5 which is a permanent fix then I'd go that route.
Old Jul 14, 2015 | 09:08 PM
Czarvette's Avatar
Czarvette
Yes, better advice than just throwing money at it.
If battery tests good, but low voltage problems persist, then two possibilities include excess parasitic drain, or weak/inoperative charging system.
To Column Lock Module Replaced - Now Low Voltage Issues
