Tire tread...when do you change?
Old Aug 19, 2002 | 10:07 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Tire tread...when do you change?
My original GY with 26k have 6/32 out back and 7/32 in front. How low do I go before buying Nitto's.
Yah I know, the day I drove it off the lot. [IMG][/IMG]
Old Aug 20, 2002 | 12:05 AM
lyonsh's Avatar
lyonsh
Default Re: Tire tread...when do you change? (Old Rotor Head)
You can take them down to 2/32 before you fail inspection in VA. I don't know whether that's a nationwide standard or not.
Old Aug 20, 2002 | 12:19 AM
DngrZne's Avatar
DngrZne
Before driving off Bear Mountain and totalling your Vette :sad: Learned the hard way :nonod:
Old Aug 20, 2002 | 01:03 AM
redriverjohn's Avatar
redriverjohn
I ran my original Goodyears down to the treadwear indicators with no problems except for wet traction. But they never had that anyway, so it was kinda hard to know for sure.
Old Aug 20, 2002 | 07:52 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
At this point the EMTs are hard as a rock and do not do well in rain or racing.............................time to replace when they look like:
You got a lot of life remaining in them unless they are cracking or deforming :yesnod:
Old Aug 20, 2002 | 11:15 AM
AFVETTE's Avatar
AFVETTE
This past Feb I had a local GY dealer measure my tread depth to see when I'd be needing new tires they came in at 5/32 with 12K miles. I'm getting ready to turn 18K miles and it doesn't look like they have worn any more since then. I'll go have the GY man take another measurement. I'm told the rubber compound where I'm at right now gets very hard and the tires sort of go into a "no wear" mode for a while. They do feel a little more greasy but I was chalking that up to the Z06 sway bars which allows me to drive a little more aggressively.
It's a daily driver but will plan on avoiding rain just to be safe.
Tom
USAF Retired
[Modified by AFVETTE, 9:16 AM 8/20/2002]
Old Aug 20, 2002 | 02:45 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: Tire tread...when do you change? (AFVETTE)
I've read something to the effect, "Two thirds of your tread wear occurs in one third the miles." Possibly someone experience. More important, with wide tires, you are very likely to hydroplane when the tread is still barely legal. If you're there, don't go out in any downpours. :cheers:
Old Aug 20, 2002 | 03:22 PM
wkasak_07Z06's Avatar
wkasak_07Z06
GY runflats are crap, replace them now! Had an accident because of mine. I had to get new GY's, because of insurance reasons, but want to switch them out for another brand ASAP.
Old Aug 20, 2002 | 03:34 PM
fight4yourrights's Avatar
fight4yourrights
Default Re: Tire tread...when do you change? (wkasak_98Coupe)
Rear tires I like to run pretty bald, but you MUST be aware that your tires are trashed if you do this.
That means no driving in the rain, taking extra care even on dry roads, etc...
Why do I do it? It's fun. Once they are shot, you can really rag on them.
I'd say get down to 5/32", grab a video camera and go smoke the rest off them.
Front tires I never let get below 5/32". Too much counts on them.
Old Aug 20, 2002 | 08:06 PM
mozin's Avatar
mozin
Check you rear tires in the centers. Mine wore out in the centers while the outer edges were fine. At 4/32" in the centers I was driving very very carefully in the wet so I bought new Michelin Pilot Sport A/S ZPs and never looked back. :seeya
Old Aug 20, 2002 | 10:42 PM
duosy's Avatar
duosy
2/32 is minimum depth in Michigan. That is about where the wear bar is even with the tread.
Old Aug 20, 2002 | 10:58 PM
Old Rotor Head
Thanks guys. After thinking about going off Bear Mountain I ordered new Nitto's and Z06 wheels today. Not worth tearing up the Vette worrying about a few ?/32's. :smash:
To Tire tread...when do you change?
