C5 headlight motor?
Old Jul 22, 2015 | 08:06 PM
riverrat68's Avatar
riverrat68
Default C5 headlight motor?
A Brother Vette owner (C-5_ turned off the headlights and one when it closes continues to run for about 4 or 5 seconds. Any thought s on what he should do? Other than to but a C-6 or C-7.
Thanks in advance.
Old Jul 22, 2015 | 08:12 PM
frsr06's Avatar
frsr06
Plastic worm gear is stripped. Hundreds of threads on replacing the plastic gear with a brass gear. Here's one.
https://www.corvetteforum.com/forums...l-in-here.html
Old Jul 23, 2015 | 12:41 AM
striper's Avatar
striper
I agree with replacing the gear with a bronze one. At the same time replace the plastic stops, it will also help and they are very cheap. Buy your parts from Rodney Dickman.
Old Jul 23, 2015 | 03:46 AM
LoneStarFRC's Avatar
LoneStarFRC
Also lube ALL your pivot points with a drop or two clean engine oil or a light machine oil like 3-in-One (NOT WD-40). I prefer engine oil. I usually do mine about once a year.
I have 198K+ miles on stock OE nylon gears.
To C5 headlight motor?
