Competitive mode??
Old Aug 20, 2002 | 05:06 AM
Lynn2008's Avatar
Lynn2008
Default Competitive mode??
I just now found out how to engage comp mode. Problem is the wheels won't spin on my 00 a4 in this mode. It does that garring action like I have AH and TC on, like when you just get in the car and touch nothing and try to power brake. The only time the tires will think about spinning is when the AH and TC is off. I'm told that it should be easier to spin in comp mode than in AC, TC off mode(yellow slippery when wet symbol on ). Whats the deal?
Old Aug 20, 2002 | 07:35 AM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Competitive mode?? (ericg320)
You're sure you've engaged Competitive mode? It said Competitive Mode on the DIC? Remember, you have to hold down the button for 5-7 seconds while the car is stopped (pre-2001).
Tom
Old Aug 20, 2002 | 05:04 PM
Lynn2008's Avatar
Lynn2008
Default Re: Competitive mode?? (tscales)
POSITIVE :cheers: Do I need to go to the shop?
Old Aug 20, 2002 | 06:17 PM
Tom Steele's Avatar
Tom Steele
The only thing I can think, is that when you start powerbraking, you start making the car want to slide sideways and AH kicks in...
Sounds odd to me though.
Good luck in getting a dealer to look at a problem with powerbraking! :)
Old Aug 20, 2002 | 07:25 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
It dosen't sound right to me.
The whole purpose of the Competitive Mode, as I understand it, is to ALLOW wheelspin without the TC interfering but still allow the computer to help straighten the car up if you get into trouble.
The main purpose For Competitive Mode, I assume, would be Autocrossing where Active Handling would be benificial but Traction Control wouldn't.
If you aren't showing any codes the dealer may be hard pressed to find a problem but it may be worth a shot.
Old Aug 20, 2002 | 07:41 PM
mozin's Avatar
mozin
It still sounds like you are not truly in competitive mode. The DIC should show "comp mode" and the message should remain in view unless you hit "reset". :confused:
Old Aug 21, 2002 | 02:53 AM
Lynn2008's Avatar
Lynn2008
Default Re: Competitive mode?? (mozin)
It is but as it has been explained to me my 00' has a comp mode that won't allow me to power brake but still has the TC mostly off.
Old Aug 21, 2002 | 11:42 AM
mozin's Avatar
mozin
Glad you figured it all out. I looked at your other thread on this topic and now understand there is a much greater difference in active handling 1 vs. 2 than I thought. It makes me glad I waited for the 2001 model. :yesnod:
Old Aug 21, 2002 | 01:16 PM
lostsoulny's Avatar
lostsoulny
98-00 cant power brake in comp mode. 01 and up cna they have gen2 active handling. just turn off trac totally and let her rip :yesnod:
Old Aug 22, 2002 | 12:47 AM
Pilot135R's Avatar
Pilot135R
You just touched on a question I've had for months. If you clear "Competitive Mode" off the DIC by pressing RESET, is Competitive Mode on or off? My guess is "OFF"; my hope is "ON". Thanks for any answers!
Old Aug 22, 2002 | 01:09 AM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Competitive mode?? (Pilot135R)
Not sure about all model years, but on a 2001-2002 it is still in competitive mode after clear. It is just not displaying on the DIC. Same with traction control turned completely off or any other message..
Old Aug 22, 2002 | 03:20 AM
Mike Schriber's Avatar
Mike Schriber
The computer is still in Competition Mode after you clear the message off the DIC with the reset button.
Mike :flag
Old Aug 22, 2002 | 07:58 AM
quimbo's Avatar
quimbo
Do the 98's have Competitive mode? and if they do how do you disengauge
it?
QUIMBO :smash: :smash:
[Modified by quimbo, 12:01 PM 8/22/2002]
Old Aug 22, 2002 | 11:34 AM
discountequity's Avatar
discountequity
Navigator
Default Re: Competitive mode?? (quimbo)
I would like to know more about "comptative Mode" Like does my 97 have it? How does it work? How do i engage/disable it?
Old Aug 22, 2002 | 11:38 AM
tscales's Avatar
tscales
St. Jude Donor '07
Competitive mode is Active Handling ON, Traction Control OFF. The 97 does not have it, as it never had Active Handling. The 98 might have it, as Active Handling was an option later in the year. If the text around the button says Traction Control, then you do not have it. If the button says Active Handling, or something like that, then you do have it.
Remember, for 2000 and before, the car has to be stopped to engage it. For 2001 or newer, it as 2nd gen Active Handling and the car can be moving.
Tom
Old Aug 28, 2002 | 08:02 PM
Silver Bullet 99's Avatar
Silver Bullet 99
I would also like to know if I have this feature. There is nothing around the button but the DIC does say Traction System ON/OFF. I tried holding down the button for 10+ seconds both with the car running in N and again in 1st. Looks like I'm out of luck :cry
Old Aug 28, 2002 | 08:16 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
hitting "reset" does not turn off the selected mode, it simplys clears the display :cheers:
To Competitive mode??
Old Aug 28, 2002 | 09:23 PM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Competitive mode?? (Ron G 1992)
It was introduced as an option in 1998 and made standard in, I think, 2001 (maybe 2000). If the button doesn't say anything about Active Handling, then you don't.
Tom
Old Aug 28, 2002 | 09:42 PM
Tom Steele's Avatar
Tom Steele
Standard in 2001. It was still an option in 2000.
Old Aug 29, 2002 | 03:00 AM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
Default Re: Competitive mode?? (Tom Steele)
:lol: :lol: :lol:
