A/C problems
Old Jul 26, 2015 | 12:28 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
Default A/C problems
My C5 is only blowing hot air. manifold gauges are reading close to the same on input and output but the system is pressurized. It does sound like the A/C clutch is engaging but I am not seeing a change on the gauges. I am assuming I probably have a bad compressor but I am now starting to second guess this. Partially because it is blowing air hotter than outside air temp.
I am now getting two codes as well P0361 P0441.
I know I am probably not giving enough info to be much help.
I do not have a Tech2, but I do plan on solving this issue myself rather than taking it to any garage.
Old Jul 26, 2015 | 01:46 PM
Chicago1's Avatar
Chicago1
maybe this will get you started in the right direction...
https://www.corvetteforum.com/forums...1a147a9f73d5e8
http://vette.tnreeds.com/actuator/actuator.htm
Old Jul 27, 2015 | 02:07 PM
73Corvette's Avatar
73Corvette
C5 Re-Calibrating Actuators
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module (fuse #27).
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
Old Jul 28, 2015 | 01:12 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
I have reset using the DIC. It recycles and then comes up with the same codes.
Would these codes keep the A/C from working?
Old Jul 28, 2015 | 01:21 PM
Chicago1's Avatar
Chicago1
what are the codes? did you look at those links?
Old Jul 29, 2015 | 08:14 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
Same two codes B0361 and B0441. Should I just replace the actuator or recalibrate? Anyone have the part number for the actuator?
Would these codes stop the A/C from working or is that going to be a different issue?
Old Jul 29, 2015 | 08:51 PM
lionelhutz's Avatar
lionelhutz
One code is for the feedback of the left actuator shorted to ground so it's likely worse than just being out of calibration.
Old Jul 29, 2015 | 09:08 PM
92GA's Avatar
92GA
Oldtimer
If it is a duel zone make sure you get the right actuator. The ones rock auto sale aren't the correct ones for a C5 duel zone. Ill try and find the right part number, I've post it on here before. 604-106 Check this thread.
https://www.corvetteforum.com/forums...ors-101-a.html
Old Jul 30, 2015 | 02:37 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Interesting... they had exactly what i needed
Old Jul 30, 2015 | 08:27 PM
92GA's Avatar
92GA
Oldtimer
They finally updated their site. They were selling the wrong part for C5s a while back, and guys couldn't get the part to work.
Old Jul 31, 2015 | 04:48 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
I do have a 2001 coupe the automatic electronic dual climate control system. I have replaced the original control head as the digital display had failed a couple of years ago when I first bought the car.
Looks like the GM part number is 15-72971 and the Doorman part number is 604-106 for the actuator for my car.
Not familiar with doorman. Is there some reason I should use Doorman rather than OEM, that is other than price?
I still do not know if these codes (B0361 and B0441) would cause the A/C compressor to not run or is this a separate issue?
Old Jul 31, 2015 | 10:15 PM
92GA's Avatar
92GA
Oldtimer
Don't know about the codes but the doorman part works just as good at a lot cheaper price. http://www.ebay.com/itm/Dorman-604-106-Temperature-HVAC-Air-Door-Actuator-Motor-/271929271070?hash=item3f503f631e&vxp=mtr
Old Aug 1, 2015 | 02:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
must have been 3 years back then
Old Aug 2, 2015 | 08:24 AM
92GA's Avatar
92GA
Oldtimer
NO it was this year, just a couple months ago.
To A/C problems
