Anyway to bypass "service active handling" code when using a line lock?
Old Aug 20, 2002 | 09:33 AM
RED99HT's Avatar
RED99HT
Default Anyway to bypass "service active handling" code when using a line lock?
I just got my line lock installed. Thanks Tommy from Surf Chevy. When I tried it out I got the "service active handling" code flashing on the DIC. Is there anything I can do to prevent codes from flashing up?
Old Aug 20, 2002 | 12:51 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: Anyway to bypass "service active handling" code when using a line lock? (RED99HT)
I am not sure why you would get that message.
I have a line lock and I do not get any messages related to it's use.
Look into this further to make sure it is installed correctly.
Be safe!
Chuck
Old Aug 20, 2002 | 01:09 PM
RED99HT's Avatar
RED99HT
Default Re: Anyway to bypass "service active handling" code when using a line lock? (chucschramm)
I thought it would be normal because when I dynoed my car this message appeared as well. From what I have heard you get this message because your back wheels are spinning and your front wheels are not moving which sends codes to the computer. After I shut the ignition off and then restart the car, the code goes away.
Old Aug 20, 2002 | 02:21 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
to off AH/TC and you should be fine, I have a line lock and don't get any codes or DIC Display messages :cheers:
To Anyway to bypass "service active handling" code when using a line lock?
