Recommended performance mods for newbies
OK< You just got a New C5, What should you do first? Assuming it's still Stock Here's a Quick Guide of what to buy and do first:
Replace the Intake System, A new Air Filter is not enough, Your looking at maybe 20-25 HP improvement here alone with Halltech TRIC, MTI Ram Air?
Consider a GMS MAF, at a minimum this is worth 6 HP
And Don't forget a Ported Throttle Body, Maybe another 5-6 HP
You Might as well get rid of that cheap looking air bridge, How about a Vortex Power Duct or a Halltech Cobra (MAG)
Replace your Stock Exhaust, Even if it's a Z06. The Stock Exhaust looks and Sounds bad, and even though the improvement is maybe 8-12 HP at best it's still worth the effort for the Sounds and Looks
OK now for the other little stuff:
Plugs and Wires: 2-3 HP
Throttle Body Bypass: 2-3 HP
Thermostat and Fan Controller: 5HP?
Temp Control Module: Possible 5 HP
PCM Programming or The PROgram: 15-35HP, WOW!
Bigger Radiator, Keep that HP Cool
The Big Stuff:
HEADS, Valve Springs, Titanium Retainers, Good for 30-25 RWHP
Add a Matched Cam to the Heads: Another 12-15 or 45-50 HP total
Consider the Crane 1.8 Rockers good for 12-14 HP more on top of that
Headers (long Tube or really good shorties): 12 HP if your Lucky
Z06 New Larger LS6 Intake Manifold, 20 RWHP? Could be!
BBK 80mm Throttle Body
Other things to Consider:
Nitrous: 150-250 HP, Now were talking
Supercharger: Stage I: 100-150 HP, Stage 2 150-250 HP, YEAH!
383 Stroker Package: 100 HP, If you got the time and Money
Twin Turbo: 150-300 HP, Only for the Deep Pocketed
What Good is Power if you can't Handle it?
Hotchkis Sway Bars, That C5 has got way to much Body Roll
Lower it, It's easy and well worth it
Brake Pads, The Stock ones Suck!
Rotors, Your Stock ones are going to Warp soon anyway
Shocks, Bilstien Sports If your Poor, HAL Adjustable if you can afford them, JRZ's if you want to race!
Poly Bushings, Get rid of that slop in the stock suspension
Wider Wheels and NON Run-Flats, Some g-Force 265 & 295x35x18s
What good is All that New Power and Handling without some Style?
Add some Z06 Intake Screens or maybe Brake Cooling Ducts
A Rear GM Performance Spoiler, Not only does it look cool, It WORKS
A Specter Werks GTR Aero Body
A BPP Heat Extractor Hood Looks Incredible.
Carbon Fiber Fuel Rail Covers
Custom Decals and Emblems
The Ever Popular Exhaust Plate
PIAA Lights or BPP Non-Popup Headlight Modules
Ripper Shifter and MOMO Shift ****
Logo Floor Mats
Chrome Wheels
[Modified by barkingowl, 10:29 AM 8/20/2002]
1) 7lbs ATI procharger
2) 3.90 gear w/hardened output shaft
3) spec stage 3 clutch
4) Fikse 18x11.5 rear & 18x10.5 front w/ pilot sport 335 30 18 & 275 35 18
5) Ripper
6) Drag setup to come
The mod. fever hit hard, I fight back even harder. :D
Nitrovette
[Modified by rrobert22, 10:30 PM 8/20/2002]
