Holly/LS6 Intake Install Questions, Help
Ben :confused:
[Modified by Slammed Vette, 7:56 PM 8/20/2002]
Everything else is cake for the GM manifold. the holley has a few more suprises. :rolleyes:
Ben :confused:
First and foremost take your time in doing this install for plan on spending 1.5 hours at least on the swap...
Drain you coolant fluid first and disconnect the battery.
You do not need to removed the fuel rail, just depressurize it by pressing on the relief valve on the rail.
R&R all the components; TB, lines etc.
The coolant line is for the front one on the block and the 2 others are plugs for the back.
The one thing that you should be aware of is that I had a very small vacuum line that came up from the firewall and connected to a rubber fiting on the back of the manifold. This was a PITA to connect with getting my hands in there but it needs to be done. Torque down to proper settings and you should be good to go. Refill the coolant, connect the battery and check for leaks...
There is another member here that has published the exchange and here is his link... http://tradezone.com/vette/2001man.html
If you have any questions IM me and I would be happy to help...
