1999 C5 corvette NEED HELP
Old Aug 6, 2015 | 01:47 AM
Blackbird*02's Avatar
Blackbird*02
Default 1999 C5 corvette NEED HELP
I have a 99 c5 corvette that I purchased last October but the DIC keep telling me that the ACT handling is warming up n the ACT handling light keeps lighting on the speedometer ...car does have c6 zo6 wheels ...I cleared the codes n took it for a test drive n here r the following codes that popped up P1275H P0410H P1276H ........B2482HC B2527HC ......B0017HC B0026HC B0051HC B0053HC.....B0361H B0363H B0365H B0367H......Can anyone please help !!!!
Old Aug 6, 2015 | 01:54 AM
StingrayRebel's Avatar
StingrayRebel
none of the codes you posted are relevant to the active handling system and they appear to be history codes so they have probably been stored for awhile and nothing to worry about... just clear everything and take it for a drive and see if anything pops back up... the active handling warming up message is normal and nothing to worry about... what size tires do you have on the car?
Old Aug 6, 2015 | 10:20 PM
Blackbird*02
The tire sizes are 325/30zr19 on the rear and 275/ 35zr18 on front which are 19x12 and 18x9.5 ....I took it for a drive but the car would reduce the speed ....any idea what could be wrong with it ?
Old Aug 6, 2015 | 11:13 PM
StingrayRebel
tire sizes are fine, I was asking just to make sure that wasn't causing any active handling issues... did you manually go through and reset all your codes after pulling them?... after that drive the car and pull the codes again and see what pops up
To 1999 C5 corvette NEED HELP
