Weird Intake Question...
Old Aug 12, 2015 | 08:25 PM
Forrest_H's Avatar
Forrest_H
Default Weird Intake Question...
Hey everyone!
I'm looking to get a new intake setup for my '99, as the stock air box is just broken (Latches are failing, doesn't sit right), and I'm looking to add a tiny bit of HP while I'm at it
I've ruled out systems like the Callaway Honker (as much as I want it...) and the Vararam, as this is my daily driver, and I don't want to do anything too crazy. I'm looking specifically at the Airaid, SLP Blackwing, and open air filters like that. I don't really want to do the Zip-Tie mod, as it was the cause of my broken air box
My question for you guys is this: Am I going to need to worry about water coming in if it's raining?
I apologize if this is a dumb question or if it's been answered, but google wasn't pulling much up. I'd really just like to know before I pull the trigger.
TL;DR: Will an open air filter in the rain soak up water?
Thanks guys!
Old Aug 12, 2015 | 09:43 PM
bjones7131's Avatar
bjones7131
I too wanted more air but nothing crazy so i consideed a z06 box, it has a bigger opening for more air but ended up drilling 10,
3/4" holes in my stock box at random locations. This gave me a lot more air intake and still maintained the stock original look. I installed the hood seal as a precaution for water injestion, i have driven through some real hard rainstorms with no issues. You can pick up a used z06 box fairly cheap, 40-50 bucks and if u still want more air drill holes like i did without breaking the bank. Good luck
Old Aug 12, 2015 | 10:28 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Forrest,
I've had a Blackwing on one of my cars for years with no problems. I left the radiator shroud intact, and I put a seal along the leading edge of the hood. HTH.
Old Aug 12, 2015 | 10:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Install a Blackwing and be done with it.
Old Aug 13, 2015 | 12:17 AM
I've run a Blackwing on my last two C5s and like it a lot. Easy install, no codes and a bit better performance than stock.
Old Aug 13, 2015 | 05:29 AM
Forrest_H's Avatar
Forrest_H
Hmm, never considered that option! Might just look into that. Thanks Mr. Jones!
Originally Posted by wamara
Forrest,
Excellent news! I was already looking into the seal, too. Thank you sir!
I'd really like to grab both the Blackwing and the Airaid and see if there's any real difference on the dyno, but my current funds wouldn't really permit that I do need to stop speculating and just grab one, though. Thanks!
Awesome news to hear Jack. Good to know that it shouldn't throw me any codes (unless I royally screw up).
Thank you guys so much for the quick replies! Looks like a new air filter will be on it's way soon!
Old Aug 13, 2015 | 09:26 AM
Gordy M's Avatar
Gordy M
Unless you bring in outside ambient air you will not make and meaningful HP gains. The systems you mention all pick up engine bay heated air, however a Blackwing or Donaldson type air intake may help with some intermediate HP gains. When GM was testing the Z06 air box to the standard c5 intake the found almost 2 hp gain but better intermediate response and adjusted the calibration as a result.
Old Aug 13, 2015 | 05:16 PM
73Corvette's Avatar
73Corvette
I've had a Vararam on for over a year now and have driven in some very heavy down pours... 4" in one hour a few weeks ago near Jonesboro Ark...drove for nearly 5 hours in heavy rain on a trip to Texas and the car has never sputtered or coughed one time...
I am careful to NOT drive into STANDING water, that may come up to the intakes... then your just asking for Hydro Lock...
The Vararam does NOT suck in rain......
IF the water is DEEP enough for the Vararam to suck it up and Hydro Lock... you'd probably be in DEEP enough water to flood your PCM also...
Old Aug 13, 2015 | 05:26 PM
Forrest_H's Avatar
Forrest_H
That makes sense, with my little knowledge of how cold-air intakes work. I would very much like to install a system that would draw air from my useless fog light covers (FRC so no actual fog lights ), but I think that's going to be further down the road of my ownership, when funds and time permit
Thanks so much Gordy, I really appreciate your input.
Well, crap. Now I'm actually considering a Vararam...
The Plug & Play Filters (So to speak) are my best option at this point, as I've got a failing clutch slave, musical obligations, and college looming on the horizon, but I am hoping to pick up either the Vararam or the Honker after I've come into a less hectic situation.
Thank you so much for the reassurance sir!
Thank you all of you guys putting in your input! It's heavily appreciated.
Old Aug 13, 2015 | 07:52 PM
73Corvette's Avatar
73Corvette
Your welcome... I picked up my Vararam B2 for $150 on the C5 for sale section... came with NO instructions and in pieces...It WASN'T that hard to put together... it seems like it's NOT going to fit, till you get to the very end of the install and then everything comes together and fits just fine...just takes some patience and a few time outs. I found it VERY helpful to remove the foglights when I did mine.
Good luck and have fun with it....
Oh Yeah... the Vararam made a feel it in the seat of your pants difference...
Old Aug 13, 2015 | 11:02 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I also have driven in some very heavy rains without a hic-up !!!!
Old Aug 14, 2015 | 10:42 AM
Arnie Chamberlain's Avatar
Arnie Chamberlain
I had a Vararam on my daily driver until I updated it for some real ram air - A&A style.
No issues on a daily. You won't regret a Vararam.
To Weird Intake Question...
