Goofy clunking sound
Old Aug 13, 2015 | 07:30 PM
jjaaam's Avatar
jjaaam
Default Goofy clunking sound
Here's a weird one for you experts...
When I pull out of the garage and take off down the driveway everything sounds great. I've noticed lately that when I come home and slow down to turn I hear a slight clunking sound. It's hard to pinpoint where it is coming from but it sounds like the front end somewhere.
Does this make any sense? Is there any component(s) that would be prone to rattling/clunking once things warm up from driving?
2003 stock coupe.
Old Aug 13, 2015 | 10:42 PM
corvette77's Avatar
corvette77
Sounds like a front wheel bearing to me. Mine made a clunk when turning slow. Jack the front up and see if there is play in one of the wheels.
Old Aug 13, 2015 | 11:31 PM
jjaaam's Avatar
jjaaam
A wheel bearing can cause a clunking sound?
I've had them go out on other cars before and all I heard was a loud grinding sound. This clunking isn't just one isolated "clunk"...it sounds like something is rattling.
Also, it's not speed dependent. The sound doesn't get worse or better depending on how fast I'm going. It also doesn't happen when I am turning...I hear it as I am slowing down and getting ready to turn.
Old Aug 13, 2015 | 11:36 PM
grantv's Avatar
grantv
Clunking or rattling? And thought you meant when turning... Does it happen only when you apply the brakes?
Old Aug 13, 2015 | 11:53 PM
jjaaam's Avatar
jjaaam
It's weird as heck. I don't notice it when going down the driveway fresh out of the garage. My driveway is dirt and it can be a little rough. I never seem to hear it when I'm driving around, even with the targa top off. I only really seem to notice it when I am slowing down and getting ready to turn down my driveway (??)...
Then I notice this clunking sound. It sounds like a mid-range rattle if that makes any sense. Once I turn and I'm going straight down my driveway I can hear it too. Slight ratlling/clunking. It doesn't get any worse when I turn.
I know it doesn't make any sense, and that's even more frustrating. Maybe it IS happening around town and I'm just not noticing it. Lately I've been trying to listen for it all the time but I hear it the most prominent when I'm literally slowing down to turn into my driveway - but BEFORE I make the turn.
Old Aug 14, 2015 | 05:57 AM
Cybermind's Avatar
Cybermind
Sounds like a swaybar endlink is loose or damaged.
Old Aug 14, 2015 | 04:18 PM
FSJim's Avatar
FSJim
It could be the rear axle nuts.. Is it a manual? Can you feel the clunk through the shifter? I had a similar issue with my 04 m6 and it was the rear axle nuts. Greased the shafts and torqued to GM spec and the clunk went away.
Old Aug 14, 2015 | 04:51 PM
Forrest_H's Avatar
Forrest_H
This was the case with my weird clunking.
Could not figure out for the life of me what was wrong, and very nearly bought new transmission and engine mounts. Then one day, I pushed on the trunk and heard the clunk. Looked under, sure enough, my rear swaybar endlinks were loose
I'd check those first, it's usually really easy to tell.
Old Aug 14, 2015 | 07:49 PM
jjaaam's Avatar
jjaaam
No...it's an automatic...
Old Aug 14, 2015 | 07:51 PM
jjaaam's Avatar
jjaaam
OK...stupid question time...
You say it's easy to tell. What would I be looking for? I had it up on stands a few weeks ago and looked at them and they didn't seem overly worn or degraded.
Old Aug 14, 2015 | 09:31 PM
feeder82's Avatar
feeder82
Try retorquing the end links The lower sway bar clamp nut to 70ft lbs the upper clamp bolts to 49ft lbs the end link nuts to 53ft lbs
Old Aug 16, 2015 | 06:23 AM
Forrest_H's Avatar
Forrest_H
Not stupid at all! Trust me, I'm probably just as new to this as you.
Whenever I heard the creaking, I went underneath and saw that mine were actually slightly frayed. When I give them a little force, they actually produced the same creaking noise, albeit quieter. It was really as easy as tightening them back down. This might not be the case for you, but I figured it might be worth a try
Old Aug 16, 2015 | 09:58 AM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Sway bar bushings may need some grease. Pin point the noise. Lots of moving parts that can make noise.
Old Aug 25, 2015 | 03:59 PM
DDario's Avatar
DDario
4th Gear
I've been chasing down a similar "clunkety-clunk" when going over speedbumps or out of driveways. Checked front and rear sway bar & links, wheel hubs, bushings. Replaced or tightened damn near everything including the subframe bolts. After all that, I could only assume it was worn ball joints (being about the only thing remaining).
Anyway, replaced my brakes recently & the spring clips on the calipers just kinda fell out, so I bent them back a bit. And what do ya know.... no more clunkety-clunk....
Seeing as you are slowing when you hear the clunk, you may check your brake clips first, cheapest fix by far
To Goofy clunking sound
