Need help with a code
Old Aug 18, 2015 | 02:38 AM
skeeters65's Avatar
skeeters65
Default Need help with a code
Hey guys can someone tell me what this code means?
2001 Z06
28-TCS C1214 H C
Old Aug 18, 2015 | 04:42 AM
zachaeous's Avatar
zachaeous
Default code
here is what is means:C1214 Sol Valve Relay Contact or Coil CKT Open
I had this code and had to change the relay in my ebcm. mine is a 2001.
Old Aug 20, 2015 | 01:14 AM
skeeters65's Avatar
skeeters65
What does it entail to do this and how do I know if that is my problem? Was it hard? Any write ups on it?
Old Aug 20, 2015 | 01:32 AM
StingrayRebel's Avatar
StingrayRebel
https://www.corvetteforum.com/forums...r-fleabay.html ... simple and easy fix and most of the time you can just resolder the broken solder joints of the relay and not have to replace it
To Need help with a code
