C5 corvette will not unlock.
Old Aug 19, 2015 | 09:06 AM
James Granger's Avatar
James Granger
Default C5 corvette will not unlock.
I have a 98 coupe, the doors will not unlock with the key and the trunk will not pop open when i turn it three times. Battery is fine, I just drove a long time on it. Desperate here! Please Help!
Old Aug 19, 2015 | 11:35 AM
Macleod52's Avatar
Macleod52
It's odd that the key will not work in the door. Is it possible the door lock or ignition was replaced so you would need two different keys?
Old Aug 19, 2015 | 11:47 AM
dadaroo's Avatar
dadaroo
If you can't get in with the key it is tie to call a locksmith.
Old Aug 19, 2015 | 12:05 PM
3sACROWD's Avatar
3sACROWD
Dumb question...have you tried you key in the passenger door? That might at least get you into the car. Your car being a 98 should have a key hole on both sides of the car.
Old Aug 19, 2015 | 12:48 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Please let us know the resolution of this, when you find it.
I can't help on this, but would just like to take this opportunity, to say thank you to all those who do, those who have the knowledge, and are right up front with helpful advice for those of us, with less mechanical knowledge or physical abilities on these issues.
Don
Old Aug 19, 2015 | 01:10 PM
James Granger
Locksmith came and opened it through the inside with a long rod.
but let me answer your comments.
Originally Posted by 8VETTE7
My money is on the battery even though you just drove it.
Wasnt the battery, car cranked right up after we got the door open.
It goes in the door and turns the lock cylinder to lock and unlock but for whatever reason quit working. its the same key for the ignition and door locks.
Yes, typically the lock works! However for reasons I cant figure out it quit working. After getting the door opened... The passenger side works again but the drivers side is out dead.
I'm thinking it may be the door lock control module? The stupid thing locks and unlocks both sides perfectly from the inside door lock buttons on the driver and passenger door.
Old Aug 19, 2015 | 10:37 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
If it is the module and you don't have time or the inclination to do the repair yourself, check this company:
http://www.autoclockrepair.com/c5_corvette_electronics
To C5 corvette will not unlock.
