NEED HELP WITH SENSORS
Old Aug 21, 2002 | 04:29 PM
QWKAZEL's Avatar
QWKAZEL
Cruise-In III Veteran
Default NEED HELP WITH SENSORS
I have a set of 01 sensors and new rims. Do I have to do anything special to the sensors or the car so that they work together correctly? Thanks in advance
Here is the 01 sensor
Old Aug 21, 2002 | 04:56 PM
QWKAZEL's Avatar
QWKAZEL
Default Re: NEED HELP WITH SENSORS (QWKAZEL)
ttt
Old Aug 22, 2002 | 02:46 AM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
You'll need a magnet to callibrate the sensors.
Make sure the vehicle has been stationary for at least 2 minutes.
Turn the ignition to ON (don't start the car)
Press the reset button to clear any IPC display warnings.
Press and releast the OPTIONS button on the DIC to scoll through and display options until the display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button again until the TIRE TRAINING message appears.
Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
Place the maget next to the wheel in the area of the valve stem.
The horn will sound indicating the left front sensor is programmed.
Next move to the right front tire.
Then the right rear tire and then the left rear tire.
The horn will sound after each sensor is programmed.
Your all set from here.
A speaker magnet will work very well to take care of this.
Tom
Old Aug 22, 2002 | 11:34 AM
QWKAZEL's Avatar
QWKAZEL
Default Re: NEED HELP WITH SENSORS (tbyrne)
thank you very much :cheers: :cheers: :cheers: :cheers: :cheers:
To NEED HELP WITH SENSORS
