Problem installing AP Racing BBK on C5Z
The calipers mounts to the included L brackets just fine. However, I can't figure out how the heck the L bracket mounts on the knuckle. Both have smooth bored holes in them, so there's no where for the GM OEM caliper mounting screw to screw into. Am I missing a part, or have I just not figured out the magic way to do this?
I can't seem to find any info online about installing this kit, so I'm scouring for similar kit install vids/pics and trying to piece things together. I don't believe they make this exact caliper anymore, but they still support it.
Here's an example of what I found for mounting an AP Racing kit on a 370z:
http://www.the370z.com/diy-section-d...g-install.html
Particularly, this L bracket in these two pics:
http://www.the370z.com/members/chris...3-img-7782.jpg
http://www.the370z.com/members/chris...6-img-7785.jpg
"Install the bracket reusing the 22mm bolts from the factory caliper with some red loctite on the threads. Torque to between 70-80 lb/ft."
How in the heck does that L bracket mount on the knuckle on my C5Z with only smooth bored holes on both parts? There's not enough thread left for a nut on the other end either.
