Problem with turn signal. Right turn signal intermittently acts like a bad lamp. (Fast flash)
All lamps are good. Unable to find flasher. Understand C5 Vette does not have standard type flasher, but rather a Flasher Module. Can anyone confirm this and tell me where it's located.
Tony!! Its been a long time since I have heard from you!! :eek: Hows it going?? I dont have the answer to you question but I thought I would at least Say Hello. Hope things are going well for you... :smash:
I do not know the answer to your question, however, I had a similar problem with my 2000 a couple of weeks ago. The right turn signal would flash extremely fast and eventually the front right turn signal stopped working and the right parking light stopped working. My dealer fixed it under warranty and all they had to do was replace the bulb. Apparenty, that one bulb performs 3 functions. Hope this helps.
I have had the same problem from time to time. Mine seems to do it after I wash the car, so I am thinking that it is a moisture problem. It is really hard to access the bulb, but it is o.k. and I have even replaced it but it will still do it. :mad
I had an issue with my brake light on the passenger side. Turn signal worked fine, the lamps were ok. It turned out to be a relay of some sort in the steering column. :eek:
